Question about Kyocera Mita FS 1000+N Laser Printer
Hi when . how can i change the settings of the margin to this printer? i print a document the margin on top was so big and the bottom page has no space at all sometimes the document was cut
  • 748 Answers
It's not a settings problem, it's a problem with aging components inside the printer.
This is an issue with bump pads on the three solenoids/clutch electro magnets like these:
Arrow points to a pad.
They are made of sort of a spongy rubber, which decomposes over time and becomes soft and sticky. Being soft they get compressed, causing the metal levers coming into contact with the solenoid core and as a consequence being released too slowly.
The solenoids are located on the right (button & lamp) side of the printer. After removing the plastic cover, looking at the side, on the left there is a control board, which needs to be unscrewed, connectors detached (you won't reconnect them wrong, each is different) and the board removed. Under it you will see two of them and a third one almost hidden behind a moulded plastic cover, which also needs to be removed.
Unscrew two screws holding the first solenoid, scrub away (using a knife) the pad and any residual adhesive, and then find some cardboard that is ~0.5mm thick (needs to be dense, not easily compressed), cut out suitable rectangles, and glue one down in place of the pad using contact adhesive for example.
Screw the solenoid back in, reconnect it and unscrew the next one, doing the same repair.
Repeat.
Note: one of the solenoids has a two-sided lever, and has two bump pads; they both need to be replaced.
Keep the thickness close to 0.5mm; if too thin, you'll get a large margin again; if too thick, printing will start at paper edge or even beyond.
This worked for me beautifully, and is based on a writeup by user
BennyFu
I used pieces of cardboard 0.55mm thick (according to my caliper...), and pressed them down firmly to get good adhesion and some initial compression to get closer to the 0.5mm optimum.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Posted on Jul 28, 2011
  • Juan Jos? Pi Feb 21, 2014
    Hi. Could add a biger picture of the solenoid and pad, please? Specially if it's from theFS1030D model.
  • Juan Jos? Pi Feb 22, 2014
    I got it, thank you.
When I print a multiple page document on tear paper roll, the first page prints correctly but the pages after that start printing too near to paper tear size or up to paper tear size. What should I do
Sounds like your top margin is not either not set properly or your documents do not have page feed command at the end. Are you sure you have the correct driver installed?
Nov 23, 2014 | Epson Dot Matrix LQ-2090 Printer
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
Canon MP480 printer prints enlarged text and shifts page margin
hi. have you tried print from other pc. ? if still the same issue maybe is a internal problem with your printer
Apr 30, 2017 | Canon MP140 PHOTO AIO All-In-One InkJet...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printing document
Did you change the top margin setting?
Make sure that the paper size is correct in the printer settings of the control panel when you print. You have to tell it what size paper you are printing on.
Aug 15, 2008 | Sharp AL-1551CS Copier
Kyocera Mita FS 1000+N Laser Printer Logo
199 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
