Question about Friedrich Heating & Cooling
I have an XQ08 model - thru the wall When turned on it provide cooling for approx 10 minutes (sometimes longer) and then it stops blowing cool air. My repair man came and adjusted the sensors which he said might solve the problem. It did not. the thermostat is set to 69, I have it set on 'cool', not money saver. When it stops cooling, and I turn it down to 60, it makes no difference and no sound indicating the compressor clicks on. Any suggestions would be helpful. thank you Ms Hill
  • 3,917 Answers
Hi
To fix a cooling problem in AC you must know the cooling process that the condenser (outside unit) pulls in the house's warm air and cools it with Freon. The cold air is then forced back into your home through the duct system. Of course if you have a window unit, this process takes place in a more limited area. Before calling a professional, here's a checklist.
Check your thermostat. It may be set on heat instead of cool. Even if the thermostat is set to a temperature below room temperature the unit will not turn on if it is set to heat.
Check your filter. This is paramount as a dirty air filter will restrict air flow and limit the efficiency of the condenser to cool the air. Typically it is recommended that the air filter be changed every month but there are some on the market today that require three month replacement. Make sure the exhaust vents in all the rooms are open and free from debris. If your duct system is in the ceiling make sure they are fully open. If the system exhausts through the floor make sure they are fully open and not covered by shoes, clothing, furniture and/or household items.
The outside unit should be free of any obstructions or debris as this will reduce the amount of air passing through the condenser.
If these items have been checked and the unit is still not running call a repair person for cleaning the condenser and checking the Freon level.
Also please check the bellow useful link to diagnose what is wrong with your AC…
http://www.inspectapedia.com/aircond/aircond15e.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 22, 2010
My nine year old 40 inch tv that is seldom used turns on to a perfect picture. 8-10 minutes later the screen goes black but audio is fine. Turning it on and off does not rectify the problem.
Could be a dry joint or something failing as it heats up. Prove this by using a fan to blow cool air into the circuitry and the picture should last longer.
Gently tapping around the circuitry with the handle of a small insulated screwdriver or similar might provide a result, perhaps the location of the fault. There is also freezer spray that can sometimes help by cooling a suspected component.
Sep 08, 2017 | Televison & Video
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Stopped cooling
more info needed, does the compressor turn on, if not thermostat or compressor issue. if it does turn on it can be that the evap is frozen. check with GE site to find out how to reset the controlling board.. normally its as easy as set to off and unplug for 10 minutes.but before using again you must thaw the evap completly,,w/,blow dryer and remove back wall on the inside of the freezer to expose the evap coils
Apr 06, 2014 | GE PFSS5NFZSS 25.1 cu. ft. French Door...
Even though I let my car run for 20 minutes to warm it up, when I get in the heater is still blowing out cool air. When I start driving, it blows out warm air. But when I stop for a stop sign or light,...
check the heater hoses going from motor thru firewall to heater core / if they get warmer when motor is at 2000 rpms or higher then most likely problem is heater core stopped up / if the hoses dont change then thermostat could be stuck open ! good luck
Jan 04, 2011 | 1995 Geo Prizm
Model #LG LWHD1500ER The fan to cool no longer runs on the low speed. It will just humm. On "energy saving mode" the unit does not always turn on to cool. On the "cool mode" when the fan is on high it...
www.appliancefactoryparts.com/content/.../118816.pdf - United States
Above is your service and repair manual, with this you will be able to troubleshoot and repair your Aircon.
I suspect, your thermostat may have a faulty sensor?
factoidz.com/troubleshooting-your-air-conditioning-thermostat/
http://www.inspectapedia.com/heat/Thermostats.htm
Below is a DIY AC, troubleshooting how to. http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 26, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Jun 22, 2010 | Heating & Cooling
I bought a haier electronic control air conditioner model HWR10XC6 on 6/30/08. I installed it. When I try to use the cool mode the air conditioner will only blow out cold air for about 5 - 10 minutes and...
It sounds as if the compressor (that provides the cooling) is cutting out due to either a faulty thermostat or is itself overheating.
Obviously check the thermostat is able to move between it's minimum and maximum levels, anthat this corresponds to the compressor cutting in and out.
With maximum cooling selected, the compressor should not cut out untill the thermostat says it's cool enough. If it does, there is a fault, and you have every right to a refund or a free repair/ replacement.
The fault is usually centered around the compressor electrical components if it is not under any warranty, but it should be. Even if the store does not want to know, the manufacturer should back it for 1 year.
Thanks for using Fixya!
If you need to attempt repair - ask again.
Jul 06, 2008 | Haier Heating & Cooling
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
47 people viewed this question
Top Friedrich Heating & Cooling Experts
acidjazzok
acidjazzok
Dennis Boxerman
Donni Steen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
