Question about Dryers
How to replace a belt on a westinghouse LD 605e dryer?
    Problem Solver:
  • 7 Answers
If you go to Readers Digest website there is a special how to repair dryers. Most electric dryers are pretty much the same exept the way the drum setsand how parts are situated. Hope this helps.
Posted on Apr 22, 2008
Cual es el codigo de acceso para canales de tv LD-2240
Codes are stored in the remote. A Westinghouse remote should be able to control your TV directly. If you are using a universal remote, you will have to perform a code search to find something that will work.
Jan 15, 2016 | Westinghouse Televison & Video
Tip
Westinghouse Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For all Westinghouse models use this diagram:
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Replacing belt on westinghouse 5kg LD505E dryer
Check YouTube - there are tons of videos on replacing the belt in dryers. You have to dismantle the frame in order to wrap the belt around the drum. Sheet metal screws hold dryers together - it is a fairly simple job, once you are acquainted with the general procedure.
Feb 01, 2015 | Dryers
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Westinghouse de600a0dw2
You'll have to trouble shoot it... the belt either jumped off the motor pully or it may have broke. Either way you'll have to disconnect it and inspect it. Remember to always unplug the unit when servicing it. If the belt broke it is not hard to replace. The drums are held by gravity on rollers. Simply lift enough to get new belt pass the roller. If there are upper rollers in the way... simply remove them. Don't remove lower rollers. Lift the drum enough to install the belt and replace the upper rollers, relocate the new belt and close it up. Done.
Dec 25, 2013 | White-Westinghouse White Westinghouse...
Westinghouse LD605E dryer drum belt replacement.
Go to www.repairclinic.com and enter LD605E. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Westinghhouse video showing disassembly and belt replacenent.
Aug 31, 2017 | Dryers
Our westinghouse ld 4655vx just shut off bye itself and won't turn back on
Check and replace its main power regulator board. It is faulty. Not working.
Jan 30, 2013 | Westinghouse Televison & Video
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Feb 02, 2012 | Televison & Video
Westinghouse LD 605E Sensor Dryer It makes a loud banging noise when turning. Drum seems to be loose. Any ideas?
According to your description listed your rollers to the drum have failed. Your rollers support the drum and weight of clothes during rotation. They are not difficult to replace if your mechanically inclined. The model number of the unit seems to be incorrect, I am unable to direct you with parts or directions without more information.
Good Luck
Jul 15, 2011 | Dryers
Dryers Logo
214 people viewed this question
Top Dryers Experts
