Question about Cameras
My headphones our the Philips sbc HN110 Noise Canceling headphones as they shorted out because of a little wiring was loose on the right headphone they do work with good quality but shorts out eventually or almost completely and stop working
SOURCE: Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Posted on Oct 26, 2008
Michael_007
SOURCE: PHILIPS HEADPHONES SBC hc 8440
Hi there!
OK I know it is little late to response but if someone will google it, might find the solution, they are still selling it though. I just got my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small power in it, however you have to charge it. So connect the small charging cable into the base unit and the headset and make sure the switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity supply. Connect the audio connector from the base to the e.g. TV, PC, DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have two of the same wireless sets. So if on the base is set to # 1 the headset needs to be also on # 1. Then if you have second headset choose channel # 2 on the base and also on the headset # 2, so they are not crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
Hope it was helpful.
Michal Bohucky
Posted on Dec 28, 2008
SOURCE: Batteries for Philips wireless headphones
Actually, look at the Philips SBC HB550S battery, the black label on battery isn't going to the end of the battery's "-" side, there's few millimetres of solid metal. Look at other, ordinary rechargeable battery, for ex duracell's. This other battery has label all over battery (from "+" to "-"). So only thing you have to do to make any batteries work with you have to cut and remove this label from battery you want to use from the "-" side of the battery, about 1-2 cm, like philips one has. It's because these headphones have this extra clip in battery sockets, philips wants us, customers, to buy those extra-expensive batteries. That's as simple as it is! Hope it helps you, it definitely helped me.
Posted on May 04, 2009
  • 7 Answers
SOURCE: Left Headphone not working
well maybe because, you to cheap to by good headphones
Posted on Jun 07, 2010
  • 24 Answers
SOURCE: Left side of my Headphone
First play with the wire at the phone plug end and where it enters the ear housing;wires usually open up where they flex most.The next step requires access to the actual speaker connection inside the left housing.You'll need to disassemble it to get to the soldered connection.Use an ohmmeter to check for continuity to the phone plug end.Check both wires;signal and ground.If both show continuity,it's your speaker.The speaker should have a low resistance reading,not open.Also try another set of phones;if that doesn't work either,it's the source.
Posted on Aug 02, 2010
I have a pair of philips SHN-9500 noise canceling headphones and the left speaker is not working how do i fix this?
Unless you are really good and have the correct soldering gear, I\'d sudgest taking it to a repair centre. If you are going to have a go, you need a variable temp, needle point solder iron, a solder \'sucker\', a magnifying glass and a steady hand. The wires to each side are in s single unit. Here is a break down, from the centre, + then insulation,then the common which is rapped around that with another layer of insulation. Good luck!
May 17, 2014 | Philips SHN9500 Consumer Headphones
Headphones drop out
Cord is probably broken internally. If you are not good with wires and soldering and it is out of warranty, find someone who is or buy new headphones. You can manipulate the wire until it works and tape it in that position for a temp fix, otherwise the cord is shot.
Aug 25, 2012 | TDK 61821 NOISE-CANCELING HEADPHONES NC150
Sbc hn050 noise cencelling head phones need replacement ear pads - where and how do I buy them?
possibly the easiest way is to get a cheap similar looking earphones, and rip the sponge off.
do look at dollar shops.
Jun 12, 2011 | Philips Behind-the-Neck Noise Canceling...
PHILLIPS HEADPHONE NOISE CANCELING RIGHT SIDE BROKE FROM HEADSET CAN IT BE REPAIRED
If I can get my password for facebook back I can use it. Becouse I can not remember my password
May 26, 2011 | Philips Audio Players & Recorders
Have Philips wireless headphones SBC HC 8445. Batteries appear to be charging and there is power. Works on left side but no sound on right side.
The speaker on the right side of the headphone is dead and shorted or might have lose wiring requiring repairing like resoldering or just tapping on the right on the right side it headphone might work.
Mar 21, 2011 | Televison & Video
How do I replace the batteries in the philips sbc hc135 headphones
i got a problem too with my SBC HC 135. I never use it before, i found it in my brother's cabinet. I tried to connect the adapter (which is have 5(if im not mistaken) red lights) to the socket. and all the lamps are lit. then i tried to turn on the headphone, but the lamp is not lit. i got a little confuse about how to use this thing. What should i do?
Nov 06, 2010 | Philips SBCHC130 Consumer Headphones
I have my "PHILIPS SBC HC105" wireless headphone, it's left side is working properly but the right side of the headphone doesn't? i tried it in my many gadgets, PSP, Ipod, Mp3, T.V., Phone... and still...
Sorry, I haven't a solution, but i have the same problem and an another one i broke the wires in the right headphone. If you open this,you make a picture for me and you post it, please. Thanks
Oct 10, 2010 | Audio Players & Recorders
Can the (cut) wiring be repaired on headphones?
Yes it can, strip the wire's off, re-connect them & tape well with electrical tape avoiding any shorts & you should be working again.
Jun 20, 2009 | Audio Players & Recorders
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
