Question about Toro Super Recycler Super Bagger Lawn Mower Rear Bagger 5
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
  • 755 Answers
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Posted on Jul 22, 2010
Why won't my toro 6.5 gts start after taking blade offand replaceing it?
From flipping the mower on it's side the top of the cylinder gets slightly flooded with crankcase oil. A good priming and a few extra pulls on the starter cord is usually necessary after this type of maintenance. You'll see a few extra puff of oil smoke upon starting. This burns off in less than a minute.
Jul 15, 2014 | Toro Lawn Mower With Toro Power Tools
Toro super recycler
Push primer bulb at least 3 times. Pull starter rope until it starts. Ensure safety lever is engaged on handle.
Aug 02, 2013 | Garden
Toro gts 6.75
you will probably need to replace the tabs that pop and grab the fywheel, the springs should be replaced as well.
Jun 15, 2013 | Garden
TORO RECYCLER LAWN MOWER MODEL 20017 2006 EDITION
to far away for me to look at it i'm on the east coast
Sep 01, 2012 | Toro Garden
Toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
Aug 18, 2011 | Toro Power Lawn Mower
Toro recycler runs like ****
You will need to disassemble the carburetor and spray with carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or the jet in carb. These portals can become blocked. Replace the diaphragm as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Toro Super Recycler Super Bagger Lawn Mower Rear Bagger  5 Logo
1,850 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
