Question about Kitchen Ranges
How do I install a new boot on a front load Maytag Washer M#MAH5500BWW?
  • benderdome Jul 21, 2010
    Thank you so much for directions and for the encouragement that "it can be done". Front loaders are such a pain.
  • 1,284 Answers
Remove 2 screws holding door hinge to cabinet and remove door. Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward. Remove panel from lower clips. At top of exposed area remove 2 5/16 screws. Remove brackets under them.
Open dispenser and remove 4 screws. Careful not to drop in dispenser. Remove dispenser frame assembly.
You can now raise top of washer to a 90 degree position.
Now back to front exposed area. Grab boot where it contacts front and peel out of groove. Also remove two screws holding light assembly and remove cover. Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel. Remove front assembly by folding up and onto top.
Now we are at the boot. Remove spring and wire assembly holding boot to drum. Make note on boot position and spring position. Remove boot. Install new boot onto drum. wrap wire around drum with ends at top. Now the fun! Hook spring to on end of wire and using vise-grips, pull to other end to hook into wire. It can be done, honest.
Now just reverse to reassemble. should be instructions with boot.
Take care
Posted on Jul 21, 2010
I need a Manual for Maytag front load washer Model # MAH5500BWW
Try Googling (maytag)(MAH5500BWW)(manual) without parens.
Sep 02, 2017 | Maytag Washing Machines
Replace rear struts how to replace
Remove front panel, lay washer on side opposite the strut you are replacing, remove old strut, replace with new one.
Oct 03, 2014 | Maytag Neptune MAH5500B Front Load Washer
Acquire screens for maytag MAH5500BWW
how to clean filter on maytag neptune front load washer
Dec 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah5500bww motor/control board failure recall
I had Maytag ship a new motor and motor control board for free and installed it myself in less than an hour. There is a ten year warranty on those parts. You just have to be very firm and insist you have warranty rights by law!
Feb 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
I have a Maytag Neptune 1st Generation and the washer door gasket always molds, how to clean and how to prevent molding
The Maytag MAH300AWW was the first generation front load washer. Your MAH5500BWW is a much newer version and has a boot drain and door venting to minimize the mold. Just be sure your drain (bottom center of the boot) is clear. Use a solution of 1/2 cup of Granular Dishwashing Detergant and 1 cup of Chlorine Bleach added directly into the tub. Run the machine through a hot was cycle (with NO clothes inside) every few months and this will reduce or eliminate the mold.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Progressively louder on spin maytag neptune model# MAH5500BWW serial#C8028996LC
You have a bad rear drum bearing ( unfortunantly , so do I ) . This involves removing the inner drum and outer drum . The complete rear of the outer drum , has to be replaced , due to the bearing is already installed in the new one . Very expensive to have done and very time consuming to do yourself . You probably should invest in a different washer . Front load washer manufacturers , have not come up with a way to support the front of an inner drum as well as supporting the rear also . Until this happens , rear bearing problems and excess expense for repair , will continue to be the downfall of front loading washers .
Nov 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kitchen Ranges Logo
13 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
