Question about Uniden TRU9585-2 5.8 GHz Twin 1-Line Cordless Phone
Phone rings but can't answer dial number phone
Phone rings but can't answer --dial number phone goes back to dial tone
SOURCE: UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Posted on Jul 08, 2008
SOURCE: Dial Tone but won't call out.
Hi, I've just had this problem today and i resolved it. Does your phone have abit of noise in the background? Replace the master socket(main telephone socket) and it should be fine
Posted on Sep 08, 2008
  • 84 Answers
SOURCE: phones don't ring
Caller ID is a service that is provided by your telephone service provider and not the phone. If the phone company isn't sending your line Caller ID data, your phone won't display it. As for getting the handsets to ring, try pushing the volume up key while the handset is off, the more times you push the button, the louder the ring will get until you are at max ring volume. Also, some models have a "Do Not Disturb" feature which turns the ringer off. Without knowing which model phone you have I cannot tell you how to turn this feature on/off. but you can look it up in your manual online at http://www.uniden.com/index/manuals_results.cfm?cat=1
Posted on Apr 03, 2009
smartr10U
  • 1305 Answers
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Posted on Jun 05, 2009
SOURCE: my phone rings but i can't hear anything on the end
i have a GE 6.0 cordless telephone, i know tha it's ringing the number comes up on my television but I can't hear it ring?
Posted on Feb 01, 2010
Why does my phone only rings once, calling party hears a couple of rings and then goes to voicemail. goes to dial tone when answered after first ring.
Press menu, go to settings then scroll down to ring count and set number of rings before it goes to voice mail.
Jul 18, 2014 | Panasonic Lands Phones
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
We have an old toshiba phone system and our phone sevice told us we have a routing problem. We have 3 lines and the only number that rings now is our 3nd rollover line. It does not go to out main number...
Phone service? You probably have a Strata VI box in the back, but the pilot number and all of the hunting is part of the dial tone provider's equipment. Somewhere on the side of the box, you should be able to unplug all outside lines and plug single line phones or test the lines with no equipment on them. If the first line rolls to line 3 all by itself, then call the dial tone provider and have them test the group. You have to make sure you're not shorting out the lines. In fact, if you can get dial tone on lines 1 2 and 3, then it tends to make it their problem and not your Toshiba system.
Carl
Sep 14, 2010 | Toshiba Lands Phones
Ring tone cuts out too fast. How do I prolong dialing tone so thst I can grt to phone before it cuts out?
When the ring tone cuts out, your caller goes to your voice mail, right?
The length of time before an unanswered caller goes to voice mail is called your "ring cycle" and is set by your phone carrier (e.g. Vodaphone, Verizon, Orange, etc.)
There shouldn't be any charge to change your ring cycle, and some cell carriers will let you adjust it from your account settings on their website, but the simplest answer is just to call your carrier's customer service and ask them to change the ring cycle for your number.
For cell carriers in the US, you can call 611 from your phone to reach your carrier's customer service, but I don't know about other countries' mobile carriers.
Feb 11, 2010 | Cell Phones
Dialing out
it's not sending a signal to the phone service check your phone lines for proper connection
Jun 22, 2009 | Vtech CS5121 Cordless Phone
Phone Rings,but cannot answer
if there is no dial tone that means that the connection is not being made when you pick up the phone hence you cannot answer nor can you get a dial tone
the fact that the phone rings indicates that the land line is good so the fault is in the phone itself
Nov 06, 2017 | Panasonic KX-TG5652 Twin Cordless Phone
Uniden TRU9585-2 5.8 GHz Twin 1-Line Cordless Phone Logo
37 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
