I have a Carrier Model# FA4BNF048, It just started making rattling noise and a thump sound like a car intake, the system is still cooling fine, its just the noise that is bothering us. I managed to get the cover off to listen carefully to the noise, that seems to be coming from the blower motor, I took it of with a few just bolts and wire diconnects, to ensure there were no loose parts in there, which I did not see or felt any. The system seems to be cooling still, but the noise after the auto shut off is mind buggling. Please help. Thanks.
    Brigadier General:
  • 3,917 Answers
Hi
If your air conditioner is making a rattling noise, your fan is probably loose. Open it up and tighten the screw that is located in the center of the fan. You can also try a piece of plywood or Plexiglas that sits between the edge of the unit and the window jamb. If you bring exact measurements to the hardware store they might cut a piece of material to size. Rattling could be fixed by getting a snugger fit. You might want to take off the faceplate and check to make sure that the foam insulation isn't loosened
Call your repairman if you cant really diagnose the actual problem.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 22, 2010
  • rmalone3108 Jul 22, 2010
    I Located the fan blower, the fan was loose it looks like its worn through the center. The bolt is tight, with a jam nut securing it in place on the fan axis. Do I need a replacement of the whole blower unit or there is a way to remedy the problem?
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
2000 jeep wrangler with 35 inch tires making a rattling noise on front passenger side
make sure that the inside of the rim is tight on the hub and not sitting off it
loose/ incorrect wheel stud nuts will also cause the noise
Apr 12, 2017 | 2000 Jeep Wrangler
Clicking in the engine
here are few components that can cause such problem.Its advisable to click the link below and follow the troubleshooting to correct the problem.
Engine makes noise? http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Chirping sound coming from engine? http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
--------- Vehicle making Clunk Thump Thud noise? http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
Car Engine Overhaul Tips? http://vwrepairhelp.blogspot.com/2011/11/car-engine-overhaul-tips.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Rattle noise from engine? http://whatisbyme.blogspot.in/2012/05/2005-toyota-corolla-rattle-noise-from.html
These will help.
Thanks.
Jul 21, 2012 | 1999 Ford Explorer
There is a thumping sound coming from the rear end of my '06 Grand Prix. It isn't a constant thump and sometimes it happens when I apply the brakes
The thumping Would likely be warped rotors causing the pads to rock in the carrier, (Assuming the anti rattle clips were installed at the time brakes were replaced?) Turn or replace rear rotors
Jun 27, 2012 | 2006 Pontiac Grand Prix
Sounds like a rattle under the van when stopped or idleing
It is most likely an exhaust heat shield or a catalytic converter that is breaing apart inside. Get underthe van when it has cooled off and "thump" the exhaust with your fist to see if you can locate the rattle. Often, the heat shield welds break where they are attached to the catalytic converter. I have fixed many of them by taking 2 or 3 large screw-type hose clamps and screwing them together to make them long enough to reach all the way around the catalytic converter and tighten them down to stop the rattle. If the noise sounds like it is coming from INSIDE the converter, you will have to replace the catalyst. (or ignore the noise)
Mar 02, 2011 | Ford Windstar Cars & Trucks
Carrier furnace clicking/rattling
Hi some thing in the blower motor or combustion fan?
Feb 16, 2010 | Heating & Cooling
Engine noise- rattles when idliing whines when accelerating
internal engine or trans problem requires a specialist
Jun 27, 2009 | 2000 Ford Focus
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
