Question about GE Profile JTP18 Electric Single Oven
My GE Profile oven door opens too far
It falls open a couple of inches further than it should. It's a GE Profile JGB918SEK3SS. Any solution?
  • 87 Answers
SOURCE: Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Posted on Jun 08, 2007
vest6
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
SOURCE: What is the reset button for GE Profile JTP18?
For me the solution was in the temperature sensor. The Locked light kept flashing and the door locking mechanism kept cycling when the door was shut or if I just held the oven light switch in the closed door position. After replacing the control panel I still had the same problem. Next I turned off the breaker and then took off the wire covers on the back of the oven and disconnected the temperature sensor. I then checked the continuity of the sensor which was fine. With the sensor still unplugged, I turned the breaker back on and the panel said locked but the locking mechanism was not cycling. With power still on to the oven I connected the temperature sensor. It worked. All I had to do was press the clear button on the touch panel and everything was fine. I turned the breaker back off and reassembled the oven. Hope this helps.
Posted on Dec 12, 2008
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Posted on Jan 04, 2009
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Oven door latch will not release so that I can open the door
Try jiggling the door by the handle. Jiggle it hard, both sideways, in/out and up/down. The little piece in there that releases the door may just be stuck, and didn't move quite far enough to let the door open. These things happen.
Nov 28, 2013 | GE Profile JTP18 Electric Single Oven
How to remove the touchpad on ge profile stove, I have f7 code
On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
Please tell me where the temperature sensor on a ge range is located
Open the oven door and look in the back wall of the oven near the top. Most GE temp sensors are on the right. Some models are on the left.It is metal about 3 inches long and smaller in diameter than a pencil.
To chamge it out,unplug the oven,re,ove the retaining screw and pull it out of the oven. Pull carefully until the wire connector is exposed. Unplug the connector to completely remove the sensor.
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
I have a GE JTP18 Trutemp. It seems to be taking
sounds like a stuck relay on the control board ... can you tell if the bake or broil element is glowing during this time?
Jul 19, 2009 | GE Profile JTP18 Electric Single Oven
After self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
Dec 24, 2007 | GE Profile JKP56 Electric Double Oven
GE Profile JTP18 Electric Single Oven Logo
154 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
