Question about Franke WD-3428 Little Butler Garbage Disposer AIR Switch
Pushed down the button to do disposal and it is stuck down, won't return up, how do I unjam it?
How do I unjam it?
On the very bottom of the disposal there is a small opening in the very middle of the disposal. If you shine a light under the sink and put a mirror down on the inside of the cabinet you should be able to see this. You'll need an Allen wrench to put in the 6 sided hex hole and turn counter clockwise until the disposal turns freely. This should unjam your disposal. Don't forget you may have to hit the small reset button on the bottom too.
Jan 14, 2016 | Garbage Disposals
Spoon stuck in disposal help
Yes, crank it in BOTH directions until it frees up. There may be an allen wrench taped to the disposer or to the wall of the cabinet that works best because it gives you better leverage.
And then buy one of these at the doller store to keep stuff from falling into the disposer.
Aug 27, 2015 | Electrical Supplies
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Uppa baby vista won't lock into place when open
This is what will work. First get some WD-40 and spray it around the jammed locking pin. Give the lubricant 10 mins and then get a knife or flat head screwdriver. What you will want to do is try to pry the locking pin up. Be gentle as you are dealing with plastic and if you break the plastic locking pin your stroller is done. As you slowly pry the pin upwards you will feel or see grooves which you can use to continue to raise the locking pin. Once the locking pin is unjammed push down on it a few times to get dust,dirt or sand out of the locking pin. The pin should pop up freely every time you push down on it and let go.
Hope that helps as I also had the same issue.
Aug 25, 2012 | Vista UPPAbaby - Carlin Stroller
How to reset ace garbage disposal
it has a reset button on the side of disposal. if it is kicking the line off then use a wooden broom handle put it in the disposal and turn to unjam the unit
Nov 06, 2011 | Ace Hardware Plumbing
What wrong with garbage disposal when it won,t grind the food up and send it down the drain
Disposal is jammed or has gone off on reset. There is a red reset button on the bottom of the unit. If jammed, turn off breaker and switch.Clean out any debris so that you can get a good visual, most common problem is small piece of bone or a coin (dime or penny) stuck between the blades. Garbae disposals are hard on plumbing pipes-best solution is remove all together.
Sep 11, 2009 | Home
Garbage disposal will not go on. Breaker is on, reset has been tried.
Yes. It is possible. Is the push button in with this switch box? Because the push button could be bad.
May 24, 2009 | Emerson InSinkErator STC-BLK Sink Top...
Hello my dishwasher will not drain after wash.
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Jan 12, 2009 | Dishwashers
Water will does not drain completly the hose is not kinked nor is this unit hooked up to a disposal. maytag portable unit
  • Unjam the motor
  • Unjam the pump
Aug 26, 2008 | Maytag Dishwashers
Franke WD-3428 Little Butler Garbage Disposer AIR Switch Logo
127 people viewed this question
Top Franke Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Franke Electrical Supply Expert? Answer questions, earn points and help others
