Question about Whirlpool RF364 Electric Kitchen Range
Read out says E4 F3 what does this mean? - Whirlpool RF364 Electric Kitchen Range
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F3-E4 in your range means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 03, 2010
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Whrilpool range error code E4 -F3-
The F3-E4 error code means that the oven sensor tempature probe has shorted out and it needs to be replaced. This link http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-item-number-ap4099532.aspx shows you what the sensor looks like.It in back wall of the oven cavity usually in the upper left side. To check to see if it indeed shorted,unplug it from where it plugs into in the back panel and use a ohm meter and look for a IF GOOD ohms value of 1060-1100 ohms IF it test at ZERO ohmhs or from 1-500 ohms the sensor is going to be shorted and needs to be replaced. It will only be considered good if at room temp is 1060-1100 plus/minus 40ohms
Gene
Aug 12, 2011 | Whirlpool GR440 Electric Kitchen Range
In mid bake the oven turns off and says F3:E4
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven)
Replace Oven temperature sensor (RTD)
Sep 25, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
F3 code
F3 E0 5 Top oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E1 6 Top oven shorted Check for shorted sensor circuit, otherwise replace sensor F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E3 8 Clean range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E4 10 Bottom oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E5 15 Bottom oven sensor shorted Check for shorted sensor circuit, otherwise replace senso
Feb 24, 2010 | Whirlpool GS460 Gas Kitchen Range
I have a Whirlpool Super Capacity 465 range and received the error messages E4 F3. What does this mean?
if you call me @ 570 263 0077 i will check my fault code list and let you know what those codes meam thanks JOHN
Nov 08, 2009 | Whirlpool GR460 Electric Kitchen Range
What does E4 - F3 - mean on display on range
It means something may be wrong with the oven sensor. The Whirlpool technical manual says:
If you need help on how to do that, let me know.
Aug 23, 2009 | Whirlpool Gold GW399LXU Gas Range
F3 E4 Err
E4 error complaint whirlpool ac
Jun 03, 2008 | Whirlpool RF262LXS Kitchen Range
F3 E4 Err
although i looked up by model number and couldn't find any "lower"sensor, the tech sheet does does list it as an open lower sensor,and here's an abbreviated portion of their repair, which ultimately leads to replacing the lower thermistor that i can seem to locate
Open the back panels and make sure the indicated temperature sensor is plugged in.
Check connector P3 on the power board. Make sure it is plugged in and fully seated.
If it is not, make the proper connection
Visually inspect the wires between P3 on the power board and the indicated temperature sensor. Make sure the wires are not cut or pinched. For the following sensors, the resistance value
should read:
Lower Oven Sensor Between 931 and 2869 ω.
(Approx. 1080 ω at room temp).
replace lower thermistor
Mar 07, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Whirlpool RF364 Electric Kitchen Range Logo
357 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
