Question about Microsoft Windows 98 Second Edition for PC
How do i get my computer out of safemode - Microsoft Windows 98 Second Edition for PC
    Brigadier General:
  • 10,406 Answers
Just use CTRL-ALT-DELETE, a few times, to force it to restart.
Posted on Jul 22, 2010
    Sergeant:
  • 298 Answers
Shutdown your pc improperly and then start it, it would ask you if you want to start in safe mode
My computer screen turns blue and restarts window vista
Hi jjlishus,
I see you mentioned that you are having issues with you computer going into a blue screen then it restarts.
You can try to boot into safe mode to see if Windows Vista will Load without having the bluescreen and if it will not shut down or restart, from Safe Mode, try and do a system restore to a data where the problem has not happened yet.
From there-on see if the issue will still happen or no
Getting into Safemode:
restart PC keep on tapping F8 on your Keyboard this will prompt you options, Look for Safemode then press enter this should bring up the safemode screen.
If during the loading of safemode and still happens are any error show up or it goes to a blue screen, you can try going into safemode with command prompt.
to get to safemode in command prompt just do the same as ging into safemode and select safemode in command prompt.
once in the command prompt
Type CHKDSK , then press enter it should check the system for 5 mins or so depending on your PC/Laptops speed.
if still the issue is the same reformatting or restoring your windows back to defaults may fix the issue.
I hope that this will help,
mvincentc
Jun 07, 2012 | Acer Brand 14.1 WXGA Matte Laptop...
Windows will not load stuck on welcom screen any help with this? Please and thank you
Hi Welcome to FixYa!
If you are having this kind of problem, follow the steps below:
1)Turn off the computer completely.
2)Unplug the charger from the laptop and remove the battery.
3)Press and hold down the power button for 5-10secs. (this will drain the remaining static charges inside the computer)
4)put in back the battery and plug the charger back.
5)Try now to turn on the computer and see if you will be able to pass the Windows Welcome screen.
6)If still no go, turn off the computer again.
7)Try to boot into safemode. (Turn on computer and once you press the power button, keep on tapping on F8.. You should see a screen that has Windows Advanced Boot Options. It has different options like safemode, safemode with networking, etc.)
8)Using the arrow keys, select Safemode. You should be able to login into Windows in Safemode. You might notice that the resolution is different. Don't panic, that's normal.
9)Once you are in safemode, access the System Configuration Utility tool. Open the link to know how to access it. http://vlaurie.com/computers2/Articles/msconfig.htm
10)Once you have accessed msconfig, click on the startup tab>then click on Disable all>click on apply.
11)Click on the Services tab>put a check on the box that says, Hide Microsoft services>Click disable all>click on apply and OK.
12)it will now prompt you with a restart. Restart the computer. and it will now boot back to normal mode.
13)You should be able now to access Windows. If it is successful, there are just some startup items or services that are having conflicts while Windows is trying to load up.
If you are not able to access safemode either, pretty much you have a bad hard drive or Windows could be corrupted. Try first reinstalling Windows on you computer.
Hope this could be a big help.
Jun 26, 2011 | Dell Computers & Internet
Computer starts but screen goes blank
- You can try to fix this by performing steps below:
Boot Computer in Safemode:
- turn off the computer
- press the power button and after 2 secs tap F8 key repeatedly
- select safemode
- computer will boot in to safemode desktop
Perform system Restore
- click start > all programs > accessories > system tools > system restore
- select a date that you computer is working fine
- click next
- computer will automatically perform system restore and restart back to normal mode
Mar 17, 2011 | Acer Computers & Internet
Hi When I boot it up , the acer emblem comes up then the screen goes black with a small cursor flashing in the top left hand corner
If you are having just a blingking cursor on boot up you must check if there is a disc inside the disc tray, or kindly check as well if there is a USB flash drive plug in on your computer and if there is any please remove them while your computer boots up as your computer might boot from it and it may cause just blingking cursor.
If there is no disc or USB flash drive installed, what you can try is to boot your computer in safemode and perform a system restore. Atleast restore back your computer 2 to 3 days back before this problem happen.
To perform safemode:
- turn off computer
- press the power the botton and after 2 sec tap F8 repeteadly until you see all the safemode options
- select safemode with networking/safemode use the arrow keys to highlight it then press enter
- computer will automatically boot into safemode desktop.
To perform system restore:
- click next then select desired date then follow the on screen instructions
- once system restore is done it will automatically restart and boot your computer in normal mode.
Cheers . . .
Mar 14, 2011 | Acer Aspire 5920-6727 Notebook
My laptop has power but wont boot...please help
hi,
Try to boot you computer to safemode, turn off computer then turn it back on then keep on tapping F8, then choose safemode, if youre able to boot to safemode, do system restore going back to the time that its properly working, click start > all programs > accesories> system tools > system restore then pick a date when you think that its properly working..
If its not able to boot to safemode, you will need to reinstall the operating system using the recovery disc that came with the computer.
Hope this will help... Please rate...
Jan 20, 2011 | Acer Computers & Internet
On start up goes to the Window main screen, then shuts down
This issue can be hard or software or even both. I suggest troubleshoot on the software side first. Try going into safemode. To do it, tap F8 while you see the ACER logo during start up. Then select SAFEMODE. If the computer is not shutting down on its own in SAFEMODE, then its a software issue. You can back up your files while in SAFEMODE. After backing up your files, you can reinstall Windows using the reinstallation disc that came with the computer. Goodluck.
Regards,
Melgasbal
Feb 25, 2010 | Acer Aspire One AOA150-1504 Netbook
Ok after my computer boots up and i log in the icons come up and like a minute later it all freezes i cant do anything please help i dont have any computer experience
Try accessing safemode or safemode with networking,
if you're able to access safemode or safemode with networking without having the same problem disable start up items and services of your computer and if your able to access safemode that only means that one of the software in your start up item is causing the problem and if you're not able to access it run the hardware diagnostic of your computer ( if that's a dell you'll need to access it in f12 ) if the test passed without any errors you'll need to reinstall your operating system but if it fails then it give you an error contact tech support of dell give them error they tell you what you need to replace. By the way if your just gonna end up reinstalling your operating system, BACK UP your files first before doing so.
Feb 12, 2010 | Dell Vostro 1500 Notebook
Computer tries to start but only goes to safemode.
I just suggest you to Format your OS, make partitions and reinstall your win again,  don't forget to install a good anti-virus!
Jan 28, 2009 | Microsoft Windows XP Home Edition
Loging
Boot up in safemode and choose administrator and delete your account and make another new one.
Your documents and files will be saved in your c: drive.
To get into safemode reboot your computer and press F8 while your computer is loading before you see a screen. Scroll up to safemode and follow the screen.
Oct 27, 2008 | Computers & Internet
Xp/home
hey drup
have you tried going into safemode and in safemode, try to do system restore.
you or someone may have deleted an important file... thats why your computer wont start up normally.
please try safemode and post what happens. thanks
Apr 22, 2008 | Computers & Internet
Microsoft Windows 98 Second Edition for PC Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
