Question about Amcor 12000 Air Conditioner
Hi my ac does not throw cold air - Amcor 12000 Air Conditioner
  • Amcor Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
AC is not throwing cold air anymore?
the unit must've run out of gas.You need to get a proffessional to get it re-gased.And ask him to locate any gas leak along the copper pipes and connections.
Dec 27, 2013 | Heating & Cooling
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
My A.C. unit is not cooling my room like it was a couple of days ago it just throws out air that is not cold and when I turn it on it the air that comes out on cool mode is like the air that comes out in...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Goldstar Heating & Cooling
Service supplmental.inflatable restraint. and very low refrigerant-ac off. is burnig heating dont work.
sorry, I don't get it. Try to say again, please direct to the point what happen to your car. Let say, your air condition it doesn't throw a cold air or no cold air coming out or very low ok.
Mar 14, 2010 | 1993 Cadillac Eldorado
Ac not getting cold but everything working inside and outside
Remove your airfilter and clean it and refix it. Due to deposit of dust the filter would have totally blocked the intake of fresh air resulting in short circulation and throwing back warm air instad of cold air.
Jul 06, 2009 | Sanyo 18KS52 Air Conditioner
Ac doesn't throw cold air
hello friend, All the compressor work in above 190 v. please additional fitting in voltage stabilizer okkkkk
Jun 24, 2009 | LG LB8000ER Air Conditioner
Ac not throwing sufficient cold air
I would try recharging the system. if the recharge doesn't produce could air, this will confirm a compressor failure.Inspect the clutch function. the AC clutch should click when it is engaging the compressors actions.
May 28, 2009 | 1999 Honda Civic
My ac is not working. sometimes it cools and most of the time it just blows reg air. when it does throw cold air it smells old.
Hi the fusion has fault with a wire on a/c pump on some models or it could just need a air con service
Apr 30, 2009 | Ford Fusion Cars & Trucks
My ac turns on but it only throws hot air it used to throw it cold a few days ago, whats the problem?
Adding a can of freon is not the solution, a system that has too much freon will not work right and there is a chance that you will damage the compressor.
There are low pressure and high pressure switches at work when the system is operating.
You might have a bad switch, leaves or other matter blocking the front condenssor.
Is the system actually full?
It's best to give this problem to a certified A/C mechanic.
Oct 01, 2008 | 2002 Jeep Grand Cherokee
Amcor 12000 Air Conditioner Logo
392 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
