Question about Lands Phones
When people telephone me on my new handset i get cut off and a beeping sound occurs and the letter r comews up in the screen, the beeping sound is also present wnen i try to dial out
  • Lands Phones Master
  • 13,433 Answers
Beeping sound at first reminds me of low battery.
Posted on Apr 22, 2008
  • Ekse Apr 22, 2008
    which phone do you have?
Cordless Extension handset (non-color) screen remains blank and does not connect to Multi Function Printer.
Hi, the handset is not registered with base, to register please follow this process:
1. On handset press Menu/OK.
2. Press cursor up or down to choose "Register HS", then press Menu/OK.
3. Press Menu, 0, 6 on the control panel of base unit (MFP)
4. Press OK on the control panel of MFP.
You should hear one long beep when the handset is registered correctly. If not (three short beeps) repeat steps from 2 to 4.
Aug 02, 2012 | Brother BCL-D10 - Cordless extension...
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Mar 05, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Triple beep
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 16, 2010 | Uniden DECT 6.0 Cordless Telephone...
Handsets do not register
Press the END button to exit or erase the message. Press Menu/Select. Scroll uo or down to find Register Base. Select the option, select it and put the handset in the charging cradle of the base. A confirmation beep will sound.
Jan 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
Fax like noise
Is this a new phone?
If it sounds like a faint fax noise, most likely you are running ADSL on the line? Those noises are from the modems talking back and forth to get internet on your phone line. Look to see if you have the line filter before the telephone... this will cut out the fax like tones.
Good Luck!
Sep 13, 2009 | Uniden DECT 6.0 Cordless Telephone...
GN 9120 beeps constantly
Are you using the GN1000 Handset Lifter? And if so, are you playing music/radio through the speaker of your telephone? If this is the case the Lifter will be picking up the sound of the music coming from the telephone and interpreting it as an incoming call, hence sending a signal to the earpiece in the form of beeps. Just stop the music coming from the telephone and the beeps should stop.
If you are not playing music through the telephone, you may need to turn down the sensitivity adjustment on the back of the Lifter. Just turn the knob anti-clockwise a little bit and see if that eliminates the beeping. If the sensitivity adjustment is too high it will pick up every little noise that goes on around your desk and interpet them as the phone ringing.
If you are not using the GN1000 Handset Lifter, then the beeping may be the result of a sticking/stuck volume button on the earpiece. If you adjust the volume on the GN9120 it gives a beep when you reach the maximum or minimum volume. If a button is stuck down it will result in a constant beeping. A stuck button is generally not a user servicable problem, however a little bit of tinkering with the button may get it unstuck.
Nov 19, 2008 | GN Netcom GN 9120 Professional Headset
AT&T 9371 TELEPHONE HANDSET
I know that these were good phones, but time marches on. I would search the web to see if you can find one for sale. Try to Google and see if you can find one. But I think you might as well look at some newer models. Prices have lowered and there are many improvements now. The newest ones out are dect and they pickup less interferance.
Dec 11, 2007 | AT&T 9371 Cordless Phone
Lands Phones Logo
80 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
