FixYa.com
Tags:
Ricoh Aficio 1013 Copier
Error message of SC542
posted by grayman1 on Apr 22, 2008
When i turn the photocopier on i get an error message of SC542 any ideas on how i can fix this?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 23, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The problem is related to fusing temperature.
To resolve the problem, enter the SP mode : press the keys as per sequence given :
<clear modes(yellow)> <1> <0> <7>
keep STOP (red) key preseed for 3 seconds,
enter copy SP mode, Use OK or # keys.
press : 5 # 8 1 0 #
change the value from 0 to 1
turn the machine OFF and ON.
If the problem reoccurs, ckeck electrical connections in fuser.
check thermister, thermostat, fusing lamp etc. with the help of multimeter.
replace the defective parts in the fuser
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Copiers problems?
Copiers
Sharp Photocopie SF 2035- warm...
hello, my sharp photocopier... Answer This...
Copiers
canon copier PC720
The copier makes a grinding... Answer This...
Copiers
minolta
minolta ep 1030 copier paper... Answer This...
Copiers
cf323
same probelem Answer This...
Copiers
Nuvera 100 CP
I have a Xerox Nuvera 100 that... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
