Question about Dyson DC22 Motorhead Canister Vacuum Bagless Cyclonic Vacuum
Turbo head not spinning. is it a fuse problem. where is the fuse
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
If the motor is running its not a fuse problem not sure on this model if there is a belt that drives the head there sould be
Posted on Jul 28, 2010
Turbo head has stopped spinning
Hi Fay, it's Jack at Dyson.
If your DC39 Multi Floor's turbine head has stopped spinning, this could mean there's a blockage in the turbine head, wand, hose or lower duct hose. This could reduce the airflow passing through the machine, which in turn will affect the turbine which powers the rotating brush bar.
It's also a good idea to check the Turbine head is free of any threads, hair or other obstructions:
If you need further help once you've given this a go, you can reach our experts at the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 05, 2016 | Dyson DC39 Multi floor canister vacuum...
How do I know about the bissell 93002 when it doesn't spray water out and the brush does not spin
check the belt that drives the brush. Maybe the motor that drives it has quit. Check for power at the head. be careful it's 120 volts
Jan 06, 2015 | Bissell ProHeat Turbo Deep Cleaner Upright...
The rotating brushes on my floor setting keep stopping on carpet - even though nothing is clogging it. I have to turn my vacuum off and then back on to get it to start spinning again.
There are two things that cause this.
1) The suction is not good and is not making the turbine head run. Clean the filters/ head and check the hose for blockages
2) The Turbo head has more friction than it should. Remove the brushes from the turbo head and remove all hair etc from the bearings with tweezers.
If it still does not work the the most common problem is the bearing retainer in the turbo head has heated up and come loose. This is a very hard repair I do but for most they should buy a new turbo-head.
Keith from Dyson Repairs North Shore Auckland
Sep 24, 2014 | Dyson DC29 Animal Vacuum
Turbo head on DC39 animal will not spin. I have removed any hair etc caught around the brush but still no spinning..
I have the same problem with my DC39 Animal's brush bar. Im on my 3rd one in 9 months of ownership. The DC39 brush bar is driven pneumatically (there is no electric motor in the brush head) and switched on and off via a suction activated pneumatic ratchet within the brush head. The moving components are actuated by bellows. Ive found that the glue holding the bellows fails stopping the ratchet working intermittently at first and then completely as the bellows comes away completely. At first you can help the ratchet by tapping the brush head - the red ratchet ring can be seen to click round. This, in my opinion, is an inherent weakness of the DC39 design and cannot be easily repaired. The only solution is a new brush head. Luckily Ive got a 5 year warranty and at the current rate I will have got through about 20 brush heads !
Mar 31, 2013 | Dyson DC39 Animal Canister Vacuum
The air turbo head for my miele flamenco II S251i spins but doesn't have suction
Check all the filters as well. We have dogs and the hair clogs up the filters. We take a air hose threw our vacuum once a month and it works like new again without replacing anything
Jun 07, 2012 | Miele Vacuums
Why isnt the turbo head brush spinning
I'm sorry to hear you're having difficulties with your Dyson. As you haven't stated which model of Dyson you own, I can't provide specific advice. If you can reply and let me know which model you have, I should be able to help.
Alternatively, if you give us a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US), our Helpline advisors will be happy to help you resolve this issue with some troubleshooting over the phone.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 10, 2012 | Dyson Vacuums
Turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Jan 24, 2010 | Dyson DC08 Cylinder Bagless Canister...
Power head on epic 6500 does not work, is there a belt?
This is a bot of a blind guess, I don't know the model. But most power head cleaners I have worked on use the suction of the vaccuum to spin a turbo fan in the head (like blowing a child's windmill). The head not spinning is usually because there's not enough **** to spin the turbo fan. Check for:
Gummed up brush bearings (dirt or damp) making the brush harder to turn than it should be.
Poor suction caused by a blocked or partially blocked pipe.
An obstruction that is tactchin the beater or the turbo fan.
Blocked filters on the cleaner, reducing the **** and thereby not providing enough vaccuum to spin the beater.
Jan 18, 2009 | Electrolux Epic 6500 Vacuum
Took appart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541327
Generic problem for all Vacuums
Took apart turbo brush and
Posted by kristinscull on Apr 24, 2008
Took apart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 types of Turbo Brushes, the electric type driven by a power head or power nozzle most likely used on a canister type vacuum or a central vacuum driven by electricity and there is an air driven power head. In either case the belt should be riding on the brushroll pulley on the end or if it is an air driven power head, sometimes the pulley section is in the middle, and the other end would run off the motor pulley / shaft. If you have a flat belt it is suggested that you change the belt every 4 to 6 months, if you have a geared belt, suggested change would be one year or so. I am not sure on the Brand of turbo brush you have, but you can refer to your local vacuum cleaner dealer in your area or the yellow pages, or contact the manufacturer for a phone # or website address, some times if you have a air driven turbo power brush it may be cost efficient to replace the brush instead of repairing the turbo brush. Just a suggestion.
Example: www.turbobrush.com – this may or may not be the website address not knowing the brand name.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Dyson DC22 Motorhead Canister Vacuum Bagless Cyclonic Vacuum Logo
306 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
