Question about Symphonic ST419E TV
My Symphonic MT S/SAP TV has BA4.0.15EB across the screen and none of the buttons work. You can see the Direct TV image but there is no sound. You cannot change volume or shut it off by the button--only if you unplug from the electrical outlet. Do you have any suggestions?
  • 1694 Answers
SOURCE: reset button
No reset button for a long time on any brand of tv.....
Check horiz output transistor,fuses and power supply
components........................T.
Posted on Dec 21, 2007
SOURCE: forgotten code
the code is026.
Posted on Mar 21, 2009
ccormier007
  • 61 Answers
SOURCE: Symphonic WF 2702 has sound but no picture. The
This could be a capacitor if your lucky but can also be the horizontal transistor. The repair could cost you between 60$ and 150$
My opinion; it's not worth it.
Posted on Jul 01, 2009
SOURCE: I HAVE A SYMPHONIC TV AND CANT GET IT TO PLAY A
uyd
Posted on Nov 28, 2009
  • 74 Answers
SOURCE: symphonic volume on my tv stopped working i have
Hi
can sound be heard from headphone socket when a headphone plug is inserted if so headphone socket is faulty or the lound speaker,
Posted on Mar 14, 2010
I HAVE A SYMPHONIC 19 IN B-19WM AND I DONT HAVE THE ORIG. REMOTE..I HAVE TRIED TO PROGRAM IT WITH RCA RCU704 SERIES UNIVERSIAL REMOTE AS WELL AS A ATLAS OCAP 5 DEVICE UNIVERSAL REMOTE AND NONE OF THE CODES...
Hello
You just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Symphonic is listed in its codes. Codes are: 0906 0520
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 17, 2011 | Symphonic ST419B 19" TV
No audio on only some stations
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12/09 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
Oct 29, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No sound on channels that have SAP instead of Stereo
You can access the menus using the buttons on the set. Go to audio menu, you'll find a setting that says listen to and have choices of mono stereo or sap, choose stereo.
Oct 08, 2009 | Mitsubishi Televison & Video
Jul 01, 2009 | Symphonic ST419E TV
In need for remote code number(s)
Yes I have solved my problem. Thank you very much for the help. I came across a web site that gives you the TV codes so I can program my Direct remote.Thank you again.
Mar 31, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
TV stuck in SAP mode
The link above does not work.
Aug 13, 2008 | Sylvania 6427TE 27" TV
Tv audio feed
You most likely have the SAP mode activated. Look for a button on your remote or an item in the on-screen menus of your television called MTS or SAP. You want to set this to "Normal" or "Stereo" (or even "MONO") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you will hear other audio. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed.
Feb 14, 2008 | Televison & Video
No Sound
First of all try getting a Symphonic remote - http://www.miracleremote.com/ not that expensive. Then you can access all areas of the TV, including all sub menus and see how the audio is set-up.. Could be you have it in SAP mode, (Second Audio Programming), in which case you will hear nothing...
Bill
Nov 19, 2007 | Symphonic SC519DD 19 in. TV/DVD Combo
Symphonic SC3919
most likely your channels are in SAP mode, you need to set them up as stereo via the menu. Remote code should be 044. For VCR. turn TV to channel 2 or 3 then press VCR button
Sep 11, 2007 | Symphonic SC3913 13 in. Combo
Symphonic ST419E TV Logo
128 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
