Question about Dell Computers & Internet
I have a Dell running Windows Vista. After I had my computer in for diagnostics, I found that I can no longer switch from my user account into that of my deceased wife's. When I click on her icon, it says ''logging off.'' Eric
    Sergeant:
  • 298 Answers
This is caused by corrupt files
Posted on Jul 21, 2010
Administrator password to login not working
Microsoft's latest operating system, Windows 7, and its predecessor, Vista, offer a new layer of security that is different from previous releases, such as XP or 2000.
The earlier Windows versions treated all users as system administrators by default. With Windows Vista and 7, all accounts are treated as limited users.
The User Account Control utility provides elevated permissions when required and prompts users for those permissions.
You can control UAC behavior in Windows 7 so it does not prompt you for these permissions.
Start your computer with Windows 7 and log in as you normally would. Your desktop should appear, and any background applications should be closed.
Click the Windows "Start" orb at the lower left corner of your screen.
Click your account picture at the top right of the menu.
You will be presented with a window that allows you to make changes to your user account.
Click the link that says "Change User Account Control Settings."
Look for the User Account Control options slider.
The default option of User Account Control is to notify you only when programs try to make changes to your computer or you install new programs.
The option directly below that does the same thing but does not dim your desktop.
The "Never Notify" option at the bottom of the list eliminates the prompts for permissions.
Move the slider to the bottom of the options window.
Click "OK."
You may be prompted one last time from User Account Control to confirm your settings and reboot your computer.
or
Log in as an Administrator on Windows 7
If you've recently upgraded from Windows XP to Windows 7, you're probably wondering how to log in as an administrator. In Windows XP, the administrator account was clearly visible from the log-on page, but it's no longer there in Windows 7.
Although there is an administrator account, it must first be enabled with the Windows command prompt before you're able to use it. Enabling the administrator account lets you troubleshoot problems with programs on your computer.
Click on the "Start" button, and then type "command" into the search bar.
Right-click "Command Prompt" when the results appear.
Click "Run as Administrator."
The command prompt opens.
Type "net user administrator /active:yes," excluding the quotation marks.
Hit "Enter."
Click "Start," and then click "Switch User." Click the "Administrator" icon to log in.
Aug 04, 2013 | Computers & Internet
Tip
Remove prompt when running applicaiton in Vista / Windows 7
Are you annoyed by these notification every time you open installer and system applications?
That is the one called UAC in Vista, Windows Server 2008 and Windows 7.
What is UAC?
-User Account Control (UAC) is a technology and security infrastructure introduced with Microsoft's Windows Vista and Windows Server 2008 operating system. It aims to improve the security of Microsoft Windows by limiting application software to standard user privileges until an administrator authorizes an increase etc etc etc. Who the heck wants the definition? ^^
The simplest way to define this one is
- The Annoying prompt on Windows Vista / Windows 7 that makes your PC slow.
It is also an idiot proof application that will give you just a minimal security.
How to disable it?
1. Go to Control Panel
2. Switch to Classic View / Small Icons View (inWindows 7)
3. Click User Accounts
4. Click Change User Account Settings
5.a (Vista) Unchecked the box then
5.b (Windows 7) Scroll the Scroll bar to never
6. Click OK/Next
7. Restart your computer.
After restart, you will the difference of the speed of your computer.
Try it! hope this Tip Helps. ^^
on Jan 24, 2010 | Computers & Internet
How to do if locked out of Windows 8 laptop?
1. Run "lusrmgr.msc" to reset Dell Windows password.
In Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account password by just run the lusrmgr.msc. But you need to login your server or laptop with an account which has admin privileges. Note that resetting password with this tip might cause irreversible loss of information for the user account. This data loss will occur the next time the user logs off. You should use this command only if a user has forgotten his or her password and does not have a password reset disk.
Step 1. Start your PC and log on with an available user account which has admin privileges.
Step 2. Click "start" button, press "Win+R" to open "Run box". Type in "lusrmgr.msc" and hit Enter.
Step 3. Local Users and Computers appears, all user accounts of your computer will be list, right-click your user name and select "reset password".
Step 4. Type in a new password and type it again to confirm it, click OK.
After restarting you can login that user account with new password.
2. Remove Dell password by using a Windows password recovery tool.
This is a universal way to reset forgotten Windows password on HP Server or PC, no matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows Password Genius is designed to recover Windows password for any kinds of PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help reset server or laptop password Windows 8, but also Windows 7, Vista, XP and Windows 2000.
Step 1: Download and install Windows Password Genius Advanced on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk with CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your PC or Server and set the laptop to boot from the disk by changing devices boot order in BIOS SETUP.
Step 4: After boot from the password recovery disk, Windows password recovery tool will start automatically and display a friendly window. Then you can reset whichever account password of your PC or Server by a few clicks.
Windows Password Genius also allows user to create new admin account for your Dell Windows system without logging. With this new user, you can login your Dell computer directly and access control panel to reset other user password.
Jul 29, 2013 | Computers & Internet
Need to reset the pasword on my del inspiron 1521 with vista
1. Reboot the Windows Vista
and boot up with Windows
Vista installation DVD.
Crack Windows Vista logon
account password in minute
with the Windows Vista
installation DVD. Click on the
Repair Your Computer
option, bring up Command
Prompt to open Local Users
and Groups management in
MMC.
2. While the Windows Vista
installation interface pops up,
click the Repair You
Computer link at the
bottom-left corner.
3. Next, the System
Recovery Options dialog box
appears. There are few
options that related to
repairing Windows Vista,
looks like Recovery Console
in Windows XP:
Startup Repair options is
used to automatically fix
problems that are
preventing Windows Vista
from starting.
System Restore to restore
Windows Vista setting to an
earlier point in time.
Windows Complete PC
Restore to restore Windows
Vista from a full system
backup.
Windows Memory
Diagnostic Tool could be the
first Microsoft memory
tester toolkit that bundled
with Windows setup media.
Command Prompt is the
target option of this Vista
hacking guide. Click on this
option now.
4. In the Vista Command
Prompt, type mmc.exe and
press ENTER key to bring up
the Microsoft Management
Console.
5. Click on the File menu,
select Add / Remove Snap-
in option, locate and select
the Local Users and Groups
on the left panel, and click
Add button to add it to the
right panel.
6. Now, the Choose Target
Machine dialog box pop up.
Keep the default setting by
clicking the Finish button -
that means using the Local
Users and Groups snap-in to
manage this local computer,
and not another computer in
network.
7. Click OK button and
return to MMC windows.
Under the Root Console in
left panel, double-click Local
Users and Group that was
added earlier. Click on User
folder, locate and right-click
the target Vista logon
account that found in the
right panel.
Select the Set Password
from the right-click menu to
set a new password / reset
old password.
***Note this does not work
on all versions of Vista***
In case if you dont have a
windows vista DVD then call
DELL and ask them for a
DVD. You need to provide
the details like Name, Phone
# and Address which you
provided when you
originally purchased the
system. In case you want
the DVD to be shipped to
alternate address, you can
provide after the
confirmation.
Dont forget 2 vote if u lik it.
Jul 25, 2011 | Dell Computers & Internet
Pls how can I remove authentication password from dell inspiron B130.
This is for Windows XP, for Vista/Win 7, the names might be different but the steps will be the same. Click on Start and then Control Panel. Click on the User Accounts link. In the pick an account to change area of the User Accounts window, click on your Windows XP user name. Choose the Remove my password link. In the text box on the next screen, enter your current password. Click the Remove Password button to confirm that you'd like to remove your account password. Now that your Windows XP account password has been deleted, you will no longer need to log on to Windows XP when your computer starts. Windows will now load all the way to your desktop automatically.
Nov 29, 2010 | Dell Inspiron B130 Notebook
How to unlock a dell windows XP home adition laptop when turning on laptop?
Do not worry, we can use dell password recovery tool to complete this task. Windows Password Rescuer is designed for resetting dell Windows 7/vista/XP password. What you should do is prepare a bootable CD/DVD or USB drive and a computer you have access to. Follow four steps help you reset dell windows password without lose anything:
Note: You also can use Windows Password Rescuer to reset Windows 2008/2003/2000 local or domain password easily by these steps on dell computer.
Step 1: Download and install Windows Password Rescuer on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk. You just need to burn it to a blank CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your dell laptop or dell computer, and set the computer boot from the password recovery disk by BIOS setting. If you have trouble in BIOS setting, refer to:
How to set computer boot from CD/DVD.
How to set computer boot from USB drive.
Step 4: After boot from the password recovery disk, Windows Password Rescuer will start up and display a friendly operating window. Then you can reset whichever account password of your dell computer just by a few clicks.
You also can use Windows Password Rescuer to create a new user with administrator privileges for your dell OEM Windows without login. With this new user, you can login your dell computer directly and access control panel to reset other user password.
Jul 11, 2010 | Dell Microsoft Windows XP Home Edition
Find master password for dell inspiron 700m
If you have forgotten your BIOS or Hard Drive Password for this model, there is a master code that you can obtain from Dell Support. Simply call, Email, or use Online Chat from http://support.dell.com and give them your Service Tag, and they can help you out from there. If it is a Windows profile password you have forgotton, try accessing the Administrator account from Safe Mode (Press F8 at startup), and remove the password for the user account from Control Panel, User Accounts.
Jan 06, 2010 | Dell Inspiron 700M Notebook
Dell inspiron with windows 7 keeps restarting befor the login
Hi nickgfarris, check to see if you still have an User's account with password to protect your computer, (LOGON)?. If not open new user's account; Control Panel / New Accounts. Thanks paul7of9
Dec 31, 2009 | Dell Inspiron 530 -Intel® Pentium®...
Dell inspiron unable to start,stuck on startup repair
I assume your OS is VISTA. If the HDD diagnostics passes, there's no other way to resolve this problem but by doing complete PC Restore. Make sure you backup all your files before you do this.
To do PC Restore on VISTA, keep on pressing F8 while on the Dell logo. Then press "Repair Your Computer". Click "Next" on the keyboard layout. Then logon with your usual Windows login name. It would default to "Administrator" but you can actually choose your own user account from the drop down menu then type your password. On the System Recovery Options, choose Dell Factory Image Restore.
If this solution is helpful, would appreciate if you rate it. Thanks.
Dec 01, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
21 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
