Question about Miele 24 in. G638 Plus Free-standing Dishwasher
Miele G638 manual
Hi there, I noticed you offered another person a manual for a G638. My dog just ate our manual (no, really, he did!), and I was wondering if you could also email it to me?
if so, can you send it to visvisvis@aapt.net.au please?
Much appreciated
Andy
  • Fogs Jun 28, 2008
    If you do have the manual for the Miele G638 Plus I would love a copy. I have an inlet / drain issue at the moment.
    Thanks
    Ian
  • Anonymous Feb 25, 2009
    same - need a MANUAL
4 Suggested Answers
gwshaw71
  • 83 Answers
SOURCE: Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Posted on Dec 08, 2007
  • 4 Answers
SOURCE: The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Posted on Aug 05, 2009
  • 251 Answers
SOURCE: miele dishwaher G638 Sc,,,,Salt PC
Hi - if its flashing rapidly then there a unrecognized hardware issue -if on permanently - it could be the float switch inside the salt container is not working/jammed - of course theres no salt in the dishwasher container..
Cheers
Posted on Jul 20, 2011
In 10 minutes, the top three finishers in a hot dog eating contest consumed a total of 143 hot dogs.?
it is like- x+12+x+x-7= 143
solving the above equation, we get, x=46
which implies, A consumed x+12= 46+12= 58
B= x=46
C= 46-7= 39
If you need more help in your homework, contact Assignment Help 4 Me Get Rapid Homework Help from Professional Tutors
Jan 04, 2017 | Homework
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
Miele dishwaher G638 Sc,,,,Salt PC light is on?
Cheers
Jul 20, 2011 | Miele 24 in. G638 Plus Free-standing...
On my Dishwasher Miele G638 Plus, a red light shows up and it says PC salt, I dont know how to solve this, please help me.
Hi - its possiblily the following issues if its flashing rapidly then the electronic module maybe faulty. The other possibilties are the float switch inside the salt conatner is jammed or the reed switch for the float switch in the salt container does work.
May 30, 2011 | Miele 24 in. G638 Plus Free-standing...
Does anyone know why a Miele diswasher will start to wash fine and then stop with the inlet/drain light flashing after a few mins? I looked at the pressure stat at the bottom of motor and when i blow in it...
hi,
you may have something rapped around the impellers of the circulation pump causing low water pressure. the unit will start and stop to try to clear the blockage. if the circulation pump is really jammed the inlet/drain light will light. it could be a faulty pressure switch but they are not common to fail.
Hope this helps
May 21, 2010 | Miele 24 in. G638 Plus Free-standing...
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
Salt PC indicator light
I downloaded the manual off line and it gave me the facts I needed.
Thank you,
Markus
Sep 08, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele 24 in. G638 Plus Free-standing Dishwasher Logo
615 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
