Question about Home
Model du-h276-dcah, has proper voltage to control panel & voltage on one leg at J12 but no voltage at F1
    President:
  • 2,047 Answers
Usually spa's are a bit tricky to work with and i usually advice you get an expert to work on it as they are a bit expensive.
For such a problem as you are facing usually the first place to start trouble shooting is the heater relay this could disrupt the flow of current around the unit thereby making no voltage to F1.
Also you could check the sensor cables as these could stop voltage flow if they have an internal breakage. Other things worthy of being checked on a secondary basis include the thermostat and the current collector.
Hope this solution has been helpful?
Posted on Jul 21, 2010
Leisurerite spa
ok, what exactly is your question?
Sep 04, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a Balboa WH-R576-DCAH. All controls seem to operate ok but no heat. Both motors seem ok, pulling about 5amps each. Not an expert but was able to manualy close the relay and cause the heater to...
If the pressure switch is jumped properly and you still are not getting a call for heat, then you are having a problem with the circuit board and it most likely is going to need to be replaced.
If the heat light is coming on but no voltage is going to the heater, this would also indicate a bad board.
You can find the 52213 circuit board online at: http://balboadirect.com/52213.aspx.
Hope that helps.
Aug 02, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have a Jacuzzi circa 1998 model Z140 spa. The 50 amp gfi breaker is continually trippinhg. The electronic control box is a Balboa instruments MODEL, DU-H276-DCAH. A relay on the circuit board chatters...
Hello - sounds like you will need to replace the relay itself if possible, if not you most likely need to replace the circuit board considering its age.You can check by diconnecting the power to the board.
If you are not an electrition and you dont work with electrical STOP NOW!! and call electrition.
Following steps would be 1. Turn off breaker. 2.Disconnect wiring to the board. 3.Wire nutt off electrical to the board.
4. Turn breaker back on. If breaker does not trip , board will need repaired or replaced.
May 18, 2011 | Home
What fuse controls heater panel
there is many fuses that work different parts of the heater controls, in the battery fuse box (under the hood) fuses (f1-8 30 amp)( f1-9 20 amp )(f1-15 10 amp)(f1-64 40amp) and in the central junction box (inside the car) fuses (f2-36 7.5 amp) and fuse (f2-45 7.5 amp) all these fuses control functions of the heater control hope this helps you out . please leave feedback
Dec 29, 2010 | 2003 Ford Focus
No dryer or washer control will start the unit running. appears no power...we checked for 240v at plug it ok...
Check the 240 vac again, but measure each leg to neutral while attempting to start the appliance. Each "leg" should measure approx. 120 VAC< (half of the total voltage) and should not change when the unit is started.I think you will find that the two 120 VAC legs will read OK until start up. If the voltage value on one leg drops to 60 VAC or less and the other leg increases by the same amount, Then there is a problem with the neutral wire or the connection between the ground of your appliances and earth ground. This is very common, particularly manufactured homes. Most dryers, for example, use 240 VAC to run the heating element, but also use 120 VAC (one leg of the 240) to provide power to operate the control panel. So... every time a start is attempted, the line becomes unbalanced, the 120 VAC to the control panel suddenly drops, the control panel resets, removing the load, the 240 VAC line becomes balanced again and appears normal.
Jan 07, 2010 | Washing Machines
Power led blinking red and green wont turn on
For LG DU-37LZ30 specifically - On the power supply board, look for IC101, an 8-pin DIP IC. There will be three smaller electrolytic capacitors near it (C107, C113 and C125) marked 47uF, 35V. I'm being lazy here, but replace all three (only one is the real culprit). What is happening is that one of these caps is charged by line voltage until the IC (power supply controller) can start running. When this capacitor gets leaky, it cannot reach the proper voltage to start the controller. I used a 47uF, 50V replacement.
I have fixed two LG sets with this same problem. The other was a 26". It's a cheap fix!
Nov 02, 2009 | LG DU-37LZ30 37 in. LCD HDTV
I have sound and no picutre
Most likely you could have a fault with the Y-Sustain board or Z-Sustain board. You will need to check if you are getting the Vs & Va voltages to the baord (Vs voltage about 195v & Va voltage about 65v). If these are present then most likely the board is at fault.
Sep 12, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
AC Breaker trips and AC Fan turns slow.
Sounds like you have a bad capacitor for your squirrel cage fan , now as for the a/c unit sounds like you have a direct short in compressor to ground or leg to leg , check all wiring to make sure that it is not grounding out or melted together.
Jul 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Home Logo
154 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
