Question about Konica Minolta PagePro 1350W Laser Printer
My printer does not take in the paper....whats causing this problem?
    Problem Solver:
  • 19 Answers
Most common cause is a dirty feed roller. clean the rubber with dishwashing liquid and try again. if problem persists, have the feed clutch changed.
Posted on Jul 28, 2010
What is causing my printer to says paper jam and there isn't one. what is causing this problem
Frequently the feed roller will wear out and not pick up paper. Check for slight smudge mark on the paper. The machine will identify a jam if the paper does not reach a sensor.
Feb 18, 2015 | HP J4680 Office Jet All-In-One Printer
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
Sep 05, 2014 | HP LaserJet 4100 Printer
Canon i70 line in center of paper
Something is clogging the paper path. A foreign object may have fallen into the printer causing all the problems.
Feb 20, 2014 | Cannon i70 Printer
Paper jam too often
Here is some tips to avoid paper jam..
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams, reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what paper you should use with your printer your printer documentation will list the paper compatible with your printer.
  • Do not mix the paper you're feeding into the printer at one time. If you need to change the paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
Jan 29, 2013 | Konica Minolta Magicolor 2590M F...
My Xerox Workcentre PE120i screen says [no paper] "Add paper". but the tray is full of paper. What do you suggest I do?
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Dec 20, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
How do i fix a paper jam on my printer?
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Hope this helps. :)
Oct 02, 2010 | Office Equipment & Supplies
Hp deskjet 5550 is always had a paper jam. what do you think is the problem of my printer? what is the possible solutions?
When removing a sheet of paper from a jambed printer, you need to be careful to slowly remove the paper without tearing the paper. This could lead to a tiny piece of paper being left behind and this will cause other paper jambs.
When this happens, the printer may need to be dismantled to remove the paper.
The other cause could be that there is uneven pressure across the rollers or dirty rollers which causes the paper to feed through unevenly and results in a paper jambs.
Check the printer for pieces of paper near the rollers and gears.
Clean the rollers, make sure there are no deposits on the rollers.
May 26, 2010 | HP DeskJet 5550 InkJet Printer
Paper Jam light is on and there's no jam anywhere. What do you do?
A paper jam notification can be caused by two things. One a hard jam, paper stuck.
Two, If the paper does not reach a flag or sensor on time, the printer knows that a jam has occurred.
Most likely, you had a paper pick problem caused by dirty rollers or maybe the paper is held to tightly by the paper tray. Also a static charge on the paper can sometimes cause sheets of paper to stick together.
Don
Dec 09, 2009 | Dell 1720dn Laser Printer
False paper jam message
PRINTER TRY TO PICKUP THE PAPER,BUT PRINTER CAN'T.THE CAUSE OF THIS ERROOR IS FAULTY PICKUP ROLLER & SEPRETION PAD.SOME TIMES PAPER TRAY CAN NOT BE OPEN WHEN WE PUSH IN,IN THIS CASE PRINTER SHOWS PAPER JAM
VIJAY THAKUR
Jul 01, 2008 | HP LaserJet 2430dtn Printer
Konica Minolta PagePro 1350W Laser Printer Logo
145 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
