Question about Logitech 967437-0403 Keyboard
My logitech keyboardcausesrandom
My logitech keyboardcausesrandom spacesornoneatall, asyoucansee. this hasbeenabout2days now. it isa cordlessLX710
    Sergeant:
  • 298 Answers
This can be caused by signal failure. try changing the battery. also there might be dirt in it. open carefully and clean of alternatively with/without opening use a blower
Posted on Jul 21, 2010
How to build pentium 2
well first you need to get the following ..
  • AOpen HX45 Computer Case
  • Abit BH6 motherboard
  • Pentium II processor
  • 128 Mbyte, 100 Mhz, 8 ns, PC-100, 168-pin SDRAM
  • Focus 2001W Keyboard
  • Logitech M-S34 2-button PS/2 mouse
  • Four 9-inch cable-ties (also known as zip-ties) Garbage bag twisties will do, but won't look as good.
  • ATI Xpert@Play 98 with 8 Mbytes Display Adapter
  • AOpen 7277c 17" SVGA monitor
  • Panasonic 3 1/2" 1.44 MByte floppy drive
  • Maxtor 9136008 11.5 GByte, UDMA, EIDE hard disk drive
  • Toshiba SD-M1102 DVD drive
  • Additional IDE cable
  • AOpen FX-3D Plus ISA PnP Sound Board
  • MLi 699 Speakers
  • AOpen FM56-P PnP PCI V.90/K56Flex 56K MODEM
  • Windows 98 OEM
  • ATI DVD Player CD
Aug 13, 2014 | Computers & Internet
A coma computer enthusiast has installed an old ISA sound card in his PC. However, it locks up and doesn?t work when a tape backup unit is used on the system. What is the most likely cause of the problem...
ISA is a very old technology and cards usually require switches or links to be set to avoid conflicts with other cards. ISA is not plug-n-play like PCI or PCI-e.
The software talks to an ISA card by knowing parameters such as IRQ number, DMA number, address range. These values may be permanently set on some cards, while others allow changing via the DIL switches or jumper links. To get two ISA cards working in one PC, the two cards need to use their own IRQ, DMA & address ranges. Make sure there are no conflicts of settings on the sound card and the tape drive card.
Try changing the settings on one of the cards. The tape drive may be the easiest for this. The tape drive is probably connected via a ISA to SCSI interface card. This should have DIP switches or Links to allow the above settings to be changed.
Oct 08, 2011 | Creative Labs Sound Blaster Live! 5.1...
Two ISA server in one domain
Assuming that your objective is to have an ISA server to protect each building's separate internet connection while maintaining a separate link for the internal networks between buildings then the answer is yes.
Here are a few things to watch:
1. Each building needs to be on its own subnet
2. You can connect the buildings to each other through ISA in several ways or by using a layer 3 switch or router on each end. Either way, you'll need to provide routes between the two private networks.
3. If you only have on DC and it's handling all DHCP you'll need to make sure that the switches can handle DHCP helpers and configure this appropriately. If you need help on this, let me know.
4. If you want to have the ability to quickly configure one ISA server to handle traffic for the opposite building in the event of an internet failure you'll need to configure a short DHCP lease. That way you can re-configure the gateway and get it out quickly to the clients after a failure, i.e. if you can stand an hour without internet easily, a one hour lease would be appropriate. The price for this is increased DHCP overhead traffic on the network.
If you are looking for a true high availability solution where you'll have no downtime on either side if the internet goes down then you will need ISA Enterprise on each end and the implementation will be quite complex and well beyond the scope of what we can do here.
If any of my assumptions are wrong, let me know and I'll try to fill in the holes.
Jul 14, 2009 | Cisco Computers & Internet
IPSEC problem between ASA and Microsoft ISA
can you try lower encryption levels on each device and see if that helps? sometimes it is neccesary between Cisco and other devices.
May 18, 2009 | Cisco ASA 5510 Firewall
ISA problem
Block Inheritance settings to stop this replication
Jan 30, 2009 | Microsoft ISA Server 2004 (e84-00526) for...
How to use ISA Slot in PCI Slot
There is an adapter available if you look on computer sites for product purchases, try to google it as there or companies than make such items, might be harder to find as PCI and ISA are older connectors and even AGP is begin phased out an PCI express is the lading connector. Google ISA to PCI adapter and see what you can get your compangies to pruchases from. Your local computer hardware shop might have it call first and ask before driving out there, If you find nothing try calling Tigerdirect as they might have older stock, you never know, If to no avail you will have to try and locate an older Motherboard with the two conncectors on it and run that if possible, or find this certain ISA card you're talking about in PCI. Good luck! :)
Jan 17, 2009 | Yamaha WaveForce SW60XG Sound Card
ISA sound in Linux
Dear.
Since version 7.3, Redhat have removed support for ISA devices. If you have a older computer that uses an ISA sound device (such as my Asus L7200 laptop with Yamaha OPL3 chip), the ISA device will not be recognized. What you need to do is to download the ISAPNPTOOLS package. Unzip and untar the file and then follow the readme file's instruction to compile, install and configure it. You will also need to add the sound device module to /etc/modules.conf. After that the sound should work. Refer to the Linux Howtos for more information.
Since 2005, Linux ALSA sound architecture support pretty much have eliminated that issue even for ISA sound devices.
Oct 19, 2008 | Computers & Internet
Logitech 967437-0403 Keyboard Logo
248 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
