Question about KitchenAid Superba KFRS271TSS Stainless Steel Gas Grill
Kitchenaid Range m# KESC307HBS8, s# IMM3723566
The display fades in and out. The Range shuts off in the night and shows PF and or ERR on display. Otherwise there is no specific error shown. What do you think needs to be replaced?
SOURCE: Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
Posted on Mar 06, 2008
  • 1314 Answers
SOURCE: Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Posted on Mar 30, 2008
  • 126 Answers
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Posted on Jan 02, 2009
  • 221 Answers
SOURCE: PF code on KESC300 Kitchenaid Electric Range
its a power supply problem in your unit .the PF means power failure in the unit. just check out the power cord wire it may be also faulty .or getting cut in between so the required voltage is not been supplied to the unit so its showing this pf on the display.
Posted on Jan 19, 2009
  • 718 Answers
SOURCE: Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
Posted on May 09, 2009
Clock will not reset on Kitchenaid Superba WEMS double oven - timer works, but no clock
KitchenAid KODE507ESS
(this MAY be your model??)... you did not specify?...
This link MAY have your DISPLAY PARTS:
KitchenAid Range Stove Oven Display Board
Anthony
Mar 03, 2018 | KitchenAid Ovens
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
My display on my 2003 KitchenAid model KESC307HBS8 range was slowly diming until I could not see the display anymore. I ordered a new control panel 9782419CB and new Main Control Board 9782455 from Sears...
You have not said what problems you are having but want to know if you have wired up the unit correctly. Is that correct?
You are only saying that the configuration is wrong but not that the unit does not work....if the unit works...be happy.
For examp you say the the # 9 key turns on the oven light....are you saying it should be another key?
You may have to restate your problem. Make sure the new board is the one that substitute for your old one. If it is not, they will usually provide you with the package insert to explain the changes or differences.
Oct 19, 2013 | KitchenAid KESC307HBS Electric Kitchen...
I have a kitchen aid electric range kesc307hbs8. we lost electricity one day and when it went back on the stove began to smell burTt. the range heats up but the control panel and touch pad are not working....
Hi.It is advisable to turn off your fuse or appliance when there is a power outage..When the power turns back ,it will produce surge amount of voltage that would eventually damage your appliances.when power comes back it has a very abnormal current flow.it may rise or fall which might beyond the wires capability.meaning it goes beyond what the wire can carry..It might be that when the power supply return it gives high current and short circuit the ground and live wires of your electric range.You better check continuity using an OHMETER.MULTITESTER if there is no short circuit.If the reading of the multitester if set to ohms is too high thats beyond the maximum amount going to the right,then there is a short circuit..
Jun 28, 2011 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid model KESC307HBS8 oven not heating
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jun 10, 2011 | KitchenAid KESC307 Electric Kitchen Range
Digital display is starting to fade in and out, sometimes it is bright, then it will fade to the point you can hardly see it, then it will brighten back up. Doesn't do this all time, but it is starting to...
Sorry to read about your problem, I hope this helps you out.
you have a failing display, it will need to get replaced...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | KitchenAid KERC608LSS Electric Kitchen...
My Kitchenaid KERC506HBS stopped working, displayed E1-F5 and oven door is locked and won't open. Started smoking so we shut it off at the breaker.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.******
Jun 13, 2009 | KitchenAid KERC506HBS Electric Kitchen...
ERROR CODE # F6E1 displays and shuts down oven
F6-E1 - Return Line Not Connected - Replace control board (clock).
Dec 23, 2008 | KitchenAid Kitchen Ranges
Blank display
First, shut the breakers off and back on. This may reset the electronics. This is either a dual breaker or two linked breakers.
Oct 30, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid Superba KFRS271TSS Stainless Steel Gas Grill Logo
177 people viewed this question
Top KitchenAid Grilling Experts
Paul Carew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
