Brother MFC-9440CN Document Feeder "adds" a black blue streak 1 3/8" from the edge of each document. Flat bed scans are a-OK. Help! Help?
  • 8 more comments
  • James711 Jul 22, 2010
    The response just received doesn't address my issue. I have isolated the source of the blue/black streak as being related the feeder mechanism that feeds multiple pages. I can feed the pages by hand to the flat tray ...with no black/blue streaks 1 3/8" from the edge of the paper. There is a "notch" and "wheel" on the underside of the feeder mechanism that corresponds with the location of the streak.
    Yes.
    I have carefully isolated the source of the streak as coming from the transport mechanism...apparently "inside" the paper transport path.
    With the exception of the first "expert response" from fixya, the responses of each additional "expert" demonstrate that the "expert" hasn't read the thread of previous experts regarding the "issue".
    The issue has been isolated to the Document Feeder.
    latest action did not resolve the issue with document feeder.
    Cleaning the Corona wires was done early.
    As reported multiple times previously in this fixya exchange copies, faxes, or printing that isn't fed through the document feeder does not contain a streak.
    the issue of Document Feeder producing a "line" when the line is not produced on any other output of the machine ...has not been addressed.
  • James711 Jul 23, 2010
    The fuser is NOT the problem.
    The fuster is a good condition.
    The "problem" is the Document Feeder.
    ....as reported multiple times in the many non-solutions to the current issue.
    YOur links do not address the "Document Feeder" being the source of the streak.
    Yes.
  • 12,061 Answers
Well you have indeed sorted your own problem, what gives it aways is when you said there was a wheel that corresponds with the line, what is happening i think, is that this is leaving a very faint crease, or the paper is NOT opaque enough, and the scanners, CCD device, "Sees" this crease, ghost image, and prints it accordingly, try scanning in B&W ONLY. I bet this sort your issue. If it does, than also you need to use a more opaque paper, that will limit the Scan depth & sensitivity. If possible,put a black, sticker over that wheel, and test again, see if that helps...
Posted on Jul 23, 2010
    Dugh! I taped a white piece of paper over the "V" in the white bar.
    Problem solved.
    Congratulations .....especially for your reading the definition of the problem. None of the other (I think it has been 12) "experts" addressed the specifics of the problem.
  • 472 Answers
Try these two links below :
i hope these steps should resolve the issue
Good Luck!
  • 1,906 Answers
Remove the printer cover remove the "fuser" roller assembly; it is a series of rollers at the back of the printer dissasemble the roller that looks like it has a brown plastic sleeve on it remove the roller end, find a
"fuser film sleeve" for your model printer on ebay; remove the old fuser film sleeve; put the new fuser film sleeve on the fuser roller; reassemble everything; the printer should be fixed: however this is not an easy job to do.
  • Jim Goldsmith
    Jim Goldsmith Jul 23, 2010
    I'm soory I could not read the whole post.
    remove the document feeder cover and, clean the paper feed rollers / wheels with isoprophyl (rubbing) alcohol
    you can also rough them up a bit with fine sandpaper or, steel wool; to clean them if they are not worn too much.
    for future reference: if they are too slick and, do not grab the paper you can use rubber belt and, wheel restorer
    The paper feeder is working a-OK.
    There is something somewhere in the document feeder path that is producing a vertical bar 1 3/8" from the sheet edge.
  • 6,826 Answers
Description of Problem 100000012622
How do I clear vertical lines, streaks, or smudges that appear on printed documents?
Description of Solution 200000016173
Print a test page from your computer that shows the lines or streaks.
Determine the type of line(s) you see:
- If the line(s) are straight, well defined lines follow Procedure A: Cleaning the Corona Wires inside the Drum.
- If the line(s) are smudgy, smeared steaks go to Procedure B: Toner Cartridge Inspection S
Procedure A: Cleaning the Corona Wires Inside the Drum:
1. Power off the Brother machine using the power switch located on the right side of the machine.
2. Press down on the front cover release lever and open the front cover by pulling it towards you.
3. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops.
NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open.
4. Remove the toner cartridges one at a time, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
5. Lift the white plastic corona wire cover by lifting the tabs located on the right and left side of the cover.
6. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right several times.
Note: Be sure to return the tab to the home position. If you do not, printed pages may have a vertical stripe.
7. Close the corona wire cover.
8. Repeat Steps 5 through 7 to clean each of the remaining three corona wires.
9. Reinstall the toner cartridge(s):
NOTE: Before reinstalling the toner cartridge, shake the toner cartridgeside to side.
10. Hold the handle of the toner cartridge and slide the toner cartridgeinto the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum. Fold down the toner cartridge handle once the toner cartridge is in place. Repeat this for all the toner cartridges.
11. Push the drum unit back into the machine until it clicks into place.
12. Close the front door and power on the Brother machine.
13. Print the test page from your computer again.
- If the test page looks fine, the issue has been resolved.
- If the issue remains, and your machine is within warranty, please call Brother Customer Service Center at 1-877-Brother (1-877-276-8437) .The center is open Monday-Friday, excluding holidays.
If your machine is out of warranty, you can locate a Brother Authorized Service Center (ASC) in your area by calling the number listed above.
4. Remove the toner cartridge that matches the color of the streak, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
5. Look inside the slot where the toner was installed for paper dust, labels or a piece of paper in the slot, if you find something please remove it.
6. Inspect the toner cartridge roller for uneven coverage, if you see uneven coverage, the toner cartridge will need to be replaced.
If you find that your retailer does not carry the specific supplies and accessories you are looking for you can purchase them by calling our toll free Accessory Line on 1-877-552-MALL (6255) or shop on-line at ourwebsite at http://www.brothermall.com.
Posted on Jul 22, 2010
  • Duane Wong
    Duane Wong Jul 22, 2010
    Was that a sufficient answer to your question about streaks on the edge?
  • Duane Wong
    The blue streak could be coming from a different routing of the paper through the rollers.
    The rollers may be contaminated from past problems which were later rectified by the user.
    I wish you luck in fixing this problem on your brother printer.
  • 2,272 Answers
Check out the the rollers from where the paper passes.If any powder from the laser toners has got spilled on the paper passing roller then this problem can come up. Try this.Remove all the cartridges from the printer.Then turn the printer off.Then take a air blower and blow air in the printer where the cartridges are inserted.Also blow air every where from dust can enter.also blow in the paper tray in which the paper is placed.Clean some dust with a dry cloth if its got stuck on the roller.In some cases the toner gets stuck up and air blower does not blow that hard stuck powder.Then re check and see if the streak is coming on the paper or any difference. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Blowing air into Document Feeder is a good approach.
    I will acquire a "blower" or "canned compressed air".
    I didn't want to "apply screwdriver".
    For surety (reported multiple times to previous responders): The black/blue streak does not appear on the fax or copy if I don't use the document
    The streak is still present after blowing.
    There is a "notch" and (apparently) a roller located +/- 1 3/8" from the rear of the scanner bed of the document feeder
  • 821 Answers
Hello,please kindly check if he inks are up to gauge,if not please make sure it is well gauged and make sure you get the quality and original ink.
best wishes,
take care.
    Genius:
  • 1,478 Answers
There are few possible reasons that can cause these problem, first, the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time, thereby causing the black blue streak, you may need to clean the toner cartridge, but if problem persist, replace the toner cartridge.
Also, some toner may have spilled in the printer. If so, you'll need to clean it out.
Take care.
    President:
  • 567 Answers
Hello there thanks for asking, you should clean the corona wire,and the print drum you should also check the feeder to if its dirty.
  • 3 more comments
    The streak is not present when printing or copying from the flat bed.
    I have cleaned everything reachable without removing screws on the feeder mechanism.
    I have isolated the source of the blue (when making a color copy) and black when making black toner copy.
    I have wiped everything accessible without removing screws from the feeder mechanism.
  • Hilton Bristol Jul 22, 2010
    Thanks for the reply, you should clean the corona wires and the print drum,these problems do not only cause by dirty feeder so if you clean the feeder and still have the problem you should clean the corona wires and the print drum.
    Please let me know if it work
    you should use the appropriate cleaning tool you can choose one from http://www.google.com/products?q=cleanin...
    Hi did you clean the corona wires and the print drum?,these problems do not only cause by dirty feeder so if you clean the feeder and still have the problem you should clean the corona wires and the print drum. Please let me know if it work
    you should use the appropriate cleaning kit you can choose one fromhttp://www.google.com/products?q=cleanin...
    President:
  • 2,047 Answers
This device is a very powerful device which is an efficient printer, though only marginal for photos, is a solid choice for adding a little color to work documents.
The printer gives this streak on your documents because of the hefty toner rack which it is fitted with. The toner has been over used and is due for replacement if this is replaced the black blue streak problem can be kissed goodbye.Brother MFC-9440CN Document Feeder
Hope this solution has been helpful?
Posted on Jul 21, 2010
  • Rockme
    Rockme Jul 23, 2010
    Have you tried tracing the path which the paper follows from the feeder? along the line there are some black rubbers which roll on a metal roller try cleaning those and any other thing which is likely to put a stain on the paper along those lines
There is a vertical black line appearing when I scan or copy
To the left of the A4 scanner glass, there is a narrow glass strip. This is when the top document feeder scans from. Check for any contamination (even a small speck) on this glass at about the position of the vertical line.
Mar 29, 2015 | Brother MFC-9440CN Multifunction Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
How do I scan more than one page at a time so I have a complete document of 6 pages instead of having 6 different document
you either select add a page, or use the document feeder. The document feeder will try to scan all pages into one file.
Mar 02, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 9440CN - I am getting "Document Jam"
Take the cover off of the ADF, rub clean the rollers with a damp cloth. Make sure there is no paper stuck in the area Also, check that the sensor flags are activating. just move them back and they should bounce back to normal position. Cleaning should do the trick.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 21, 2011 | Brother MFC-9440CN Laser Printer
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
Feb 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
MFC8840D
Hinge broken left, replace 25 bucks precision roller sells them as does any brother printer dealer, yes you can fix it yourself 3 screws, no manual required
Dec 23, 2007 | Brother MFC-8840D All-In-One Laser Printer
Scanning with the brother mfc 7300c
FIRST OF ALL YOU WILL NEED TO INSTALL THE BROTHER MFC SUITES CD THAT CAME WITH YOUR MACHINE, WHEN YOU HAVE DONE THE INSTALLATION, BRING UO THE PROGRAM PAPER PORT OF YOUR MONITOR, PUT THE COPY THAT YOU WANT SCAN ON THE FLAT BED, IN THE UPPER LEFT HAND YOU WILL SEE PHOTO OR TEXT CLICK WHICH EVER YOU ARE SCANNING, NOW CLICK SCAN ANOTHER SCREE WILL COME UP AND ASK YOU IF YOU ARE USING THE FKAT BED( THE GLASS OR THE DOCUMENT FEEDER. CLICK THAT, NEXT TELL IT AGAIN PHOTO OR TEXT OR WHAT EVER THEN CLICK SCAN, ON THE SCREEN YOU WILL SEE THE SCANNING TAKING PLACE, THEN YOU WILL SEE THE SCANNED ITEM  EITHER IN MY DOCUMENTS OR MY PICTYRES DEPENDING WHERE YOU TOLD YOUR COMPUTER TO PUT THEM HOPE THIS HELPS, GOOD LUCK BROTHER SR TECH
Nov 13, 2007 | Brother MFC 7300C InkJet Printer
481 people viewed this question
jasbo
jasbo
