Question about Kenmore 73952 Gas Dryer
When I push the start button the dryer starts but won't stay running - the minute I let go of the button it stops.
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryerWhen I push the start button the dryer starts but - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_noWhen I push the start button the dryer starts but - 2_bing.gif/a>
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 22, 2010
  • 76 Answers
SOURCE: Dryer won't start when pushing the start button
bjsouth Most likely the problem with your dryer is bad motor. It is not repairable and has to be replaced. If you feel you can do it yourself, let me know and I'll help to buy new motor and provide you with instructions how to replace it. Gendos...post back
Posted on Mar 04, 2007
Buffalo12980
  • 625 Answers
SOURCE: Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Posted on Aug 21, 2007
agitateme
  • 88 Answers
SOURCE: Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Posted on Jan 17, 2008
WRMtech
  • 70 Answers
SOURCE: START AND RUN PROBLEM
check the motor relay. there are 4 wires( 2 are pink and black) this goes to the coil of the relay and must show resistance(closed) you can also jump out the 2 blue wires and see it the unit keeps running. The part number for the relay is: FSP3405281 approx 40.00US
Posted on Mar 01, 2009
  • 686 Answers
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
I have a kenmore he3 dryer that won't stay on. When I push the start button, the motor will turn the drum about a quarter of an inch then stop. I then need to push the pause/cancel button once and...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
May 16, 2011 | Dryers
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Kenmore 73952 Gas Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
