Question about Schumacher & Fast Charge Starter Charger
No output on a sf-1252ma - Schumacher & Fast Charge Starter Charger
  • 661 Answers
I hate to say this. Bringer of bad news usually ends up with a poor rating. However this is a fact that these chargers are not very high quality. I have a stack of them that are all burned out. The electronics are just really poor quality. sorry but its junk.
Posted on Jul 22, 2010
2 Suggested Answers
SOURCE: no output from charger model SF-1252MA
Yes it well may have inside the unit, worth a look anyway. If it is NOT that, then I would imagine, the Output transistor, or Voltage regulator, has Blown, if you can get a replacement, repair will be easy.
Posted on Apr 09, 2010
Testimonial: "thankyou for the advise, will check with manufacturer for parts"
The Samsung sf-560 is spitting the faxes etc. out of the back of the machine... how do I stop it from doing this and restore the output to the front tray?
The output cover in the back of the Samsung is most likely in the up position. When it is then all output will come out the back of the sf-560. To stop this from happening just close the back output cover by pushing it back down and closing the back cover. Then your output will come out the top shoot.
Jan 23, 2015 | Samsung SF-560 Plain Paper Laser Fax
Pump shuts off in very hot weather
might have the wrong motor on it, themotor hp and SF sevice facto determin the total HP output of the motor. so say it's a 1hp with a 1.65 sf it's a 1.65 hp motor ..the impeller detrmins the hp needed, it should have numbers and letters on it. welcome to my world fun huh
Jul 10, 2012 | Sta Rite Sta - Rite 2hp Max - E Pro...
No output from charger model SF-1252MA
the transformers of these chargers have whats called a thermal fuse....usually this fuse is wired inside the transformer itself....it is designed so that in case of excessive overloads or high temperature, the fuse will blow...this is to protect your home wiring from overheating and possibly catching fire.......it is a safety feature....by touching the cables together even for a moment caused an extreme overload condition which probably took the fuse out....you can still fix it but you need to open a few layers of the transformers wrapping to get access to the fuse.....some systems have other components called NTC's or PTC's....these are also temperature safety components.....chances of the regulating components going bad ae slim because their capacities are designed for high power, high temp conditions so chances are that only the fuse is gone....good luck
Apr 09, 2010 | Schumacher & Fast Charge Starter Charger
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
Sharp SF-7320 produces grainy copies
Clean the drum unit seal blade thats leaking or replace it.
Nov 11, 2009 | Office Equipment & Supplies
Output of my sharp 7850 copier is very dark
Hello sir; Check out the exposure lamp is on or not, please let me know.
Mar 09, 2009 | Panasonic Workio DP-2000P Copier
Output level
You need the S.F. Edit mode [Scale Factor]
Press Menu/NO ... edit menu appears
Turn AMS wheel until S.F. edit appears press 'yes'
Turn AMS wheel until 'Tr Level appears press 'yes'
Turn AMS wheel until the track number you want to change appears ... press 'yes'
You can now adjust the level with the AMS wheel
Press 'yes' 'SF Edit OK?' appears ... press 'yes' ... the deck starts to record over the existing track 'SF Edit appears ... when finished 'complete' appears.
dec@makehits.com
Apr 23, 2008 | Sony MDS-JE480 Mini Disc Player
Schumacher & Fast Charge Starter Charger  Logo
73 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Marvin
Marvin
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
