Question about ASUS P5GZ-MX Motherboard
Cmos setting wrong.overlocking failed! please enter setup.usb device over current status detected.system will shutdown after 15 second
  • 245 Answers
Hi zafer
Since you're familiar with overclocking I doubt that you're afraid to work on your motherboard.When you remove the battery,make sure the computer is unplugged and while you have your hands in the case it's important that some part of you,hand-forearm-anything,stay in constant contact with a metal part of the case unless you have an anti-static wrist strap.And be careful when removing the battery.Some are held in with small metal clips that you may not see if you don't know they're in there and prying the wrong way will break the battery socket.Look closely to see how it's held in before trying it.
And as rhymewurdz said,leave it out for 30 secs or so,put it back,restart and enter BIOS.You'll have to enter any changes you made to the original settings but set the CPU clock speed back to it's PROGRAMMED speed if BIOS doesn't do it on it's own.If you changed any board jumpers trying to overclock the system,put them back.
You won't gain enough performance through overclocking to make up for the instability you're going to have even if it works overclocked.The excess heat alone,unless you've planned and compensated for that,will shorten the life of your system by quite a bit.
One thing,BIOS settings won't reset your Windows password,just your BIOS password if you set one.
Any questions,post back here and someone will be here to help you out.
Bob
Posted on Aug 23, 2010
    Sergeant:
  • 298 Answers
Remove the cmos battery wait about 5-10 seconds, replace battery. warning: this should reset all your setting such as time and date including your windows password
Posted on Jul 21, 2010
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
May 31, 2010 | ASUS P5PE-VM Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Bios setup error
check your c-mose battery when power cable is unplugged the battery remove and after few seconds battery fix them and connect power cable then on the computer
Oct 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
Aug 12, 2008 | ASUS P5PE-VM Motherboard
Bios setup error
Unplug ALL Usb devices, that includes printers, cameras, pen drives, i.e. anything that plugs into a USB connector. Then try rebooting your computer. I bet your problem will no longer exist, but if it does, then you need to suspect a faulty USB connector on the motherboard or USB chipset located on the motherboard. Once the computer is booting normally without USB devices hooked up, you can start installing ONE Usb device at a time, until you find your defective USB device. The USB device drivers will need to be installed and computer rebooted at least once between the various devices. Not doing so will lead to confusion as to which USB device is causing your high current problem. It is also possible athough a bit unlikely that this procedure will cure your situation for the time being but look out for it in the future because it could be an early sign that one of your USB devices is going bad.
Aug 11, 2008 | ASUS P5PE-VM Motherboard
SYSTEM ERROR
1) if you have nothing in a USB port you will need to set bios
Try removing M/board battery for 2 to 3 hours some people say less then replace it most times it should set BIOS back to default
also check setup of hard disks master slave etc
Last resort with 15 seconds you should be able to see
press ?? key to access BIOS next boot keep pressing key see if that works
Aug 10, 2008 | ASUS M2N-MX Motherboard
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
ASUS P5GZ-MX Motherboard Logo
355 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
