Question about Tomtom Go Plus GPS Receiver
TOMTOM GO 910 problem (Formating)
Well Basicaly i am planing to format my tomtom go 910 but i need help because when i format it it ask whihc type do i want whihc is either to a "NTFS" or a "exFat" which one should i use?
E61N
  • 515 Answers
SOURCE: TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Posted on Apr 14, 2008
  • 58 Answers
SOURCE: Mobile phone
You have to put the phone in discovery mode. To do this go to options or find something that says discovery mode and it should put it in discovery mode for about 3 minutes.
Posted on Jan 10, 2009
  • 78 Answers
SOURCE: Tomtom Advert on Tomtom XL wont turn off
It's a default demo. You can remove it by changing it in your preferences, not by deleting files
Posted on Jan 22, 2009
  • 171 Answers
SOURCE: unable to download map onto tomtom one xl
If you have an older tt xl it will only take up to a 2gb sd card. Larger than that you will get errors.
Hope this helps
Posted on May 31, 2009
  • 4 Answers
SOURCE: my tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Posted on Sep 26, 2009
WILL I LOSE DATA WHEN FITTING NEW BATTERY IN MY TOTOM 910
Tomtoms store data in a non volatile format, either to an SD card, Flash memory or to a hard drive, none of the above require a battery backup.
If the battery is removed the only data that should be lost is the time and date
Jan 10, 2013 | Tomtom GO 910
GO 910 GPS Receiver: tomtom 910 formatting when turned on...
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
May 18, 2010 | Tomtom GO 910 GPS Receiver
Computor does not reconise my tomtom go 910 satnav says formatting failed computor says usb device has failed
Power on the TT 910 and then press the Reset Button on the base of the TT. It is a tiny hole with a hidden button. use a rounded object, match end or soft pencil to puch the button. Then reconnect it to the PC and the PC will see the TT. Note that you may have to reload apps and maps depending on the state of the TT.
Nov 13, 2009 | Tomtom GO 910
Faulty battery on my Tom Tom Go 910
Go to this site and get the pdf with pictures on how to do it. Just be careful with the hard drive cable. Delicate tabs.
http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
Jan 31, 2009 | Tomtom GO 910 GPS Receiver
I need motherboard for tomtom go 910.
http://www.portatronics.com/product_info.php?info=p672_TomTom-Go-910-Motherboard.html
Dec 11, 2008 | Tomtom GO 910
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
Black screen on tomtom go 910
I searched on GOOGLE, found the link and fixed my tomtom,it just needed to reset, thanks anyhow
Apr 26, 2008 | Tomtom GO 910 GPS Receiver
TomTom GO 910 - screensaver?
try this it does take a while to do.
STEP 1
Connect your TomTom to your computer1.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup1.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Dec 27, 2007 | Tomtom GO 910 GPS Receiver
Red Cross and disk on my Tomtom Go 910 GPS
plug the unit into computer and check for updates if it still has a red x after installing the up dates call tech support
Nov 11, 2007 | Tomtom GO 910 GPS Receiver
Tomtom Go Plus GPS Receiver Logo
65 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
