Question about Garmin GPS
The unit will not accept or hold a charge. The low battery sign pops up intermittantly while on charge while driving. The charging cord hook up to the unit seems to me to be a part of the problem because when touched it initiates several responses from the unit including charging and low battery. We bought the unit late last year and have not been able to use it effectively at all.
The unit was sent back to Garmin for review.
Posted on Apr 24, 2008
My garmin in nuvi 1350 will not charge it keeps saying the battery is low
Nuvi 1350 charges in 4 to 8 hours. If your Nuvi is not accepting a charge, you may have a loose or bad USB cable. Note that the Nuvi can be charged with a phone charger. Charging it with a connection to a computer moves charging time toward 8 hours and more towards infinity if you don't have the driver installed on the computer. Turn the Garmin off. If the driver ins installed in the coputer, plug the Garmin into the computer and then hold down the power button on the Garmin for 30 seconds.
Sep 10, 2017 | Garmin GPS
Why the battery of my unit is not charging? and When do i know the rechargeable battery is to be replaced?Coy
You need to replace the battery when it no longer charges or when the battery won't hold a charge and dies quickly. the charging symbol will light, as the charger is working, but in your case, the battery is not accepting or holding the charge.
Is this a hand-held DVD player?
Oct 23, 2015 | Televison & Video
HI I DIDNOT CHARGE MY PHONE A FEW DAYS WHEN I TURNED IT ON IT SHOWED LOW BATTERY BUT I CHARGED IT IT IS STILL NOT SHOWING ANY THING NOT EVEN LOW CHARGE SIGN IT IS 3GS PHONE
try restating your iphone by holding both the lock button and the home key. hold the home key for 10 sec and then hold the lock button until you see the apple sign
Mar 01, 2011 | Apple iPhone 3G
Why dose the battery never fully charge
This is usually a sign it has 1 or more bad cells or has developed memory. You can try draining it all the way down and then recharging it to recondition the battery, if it's a memory issue. This may take 2 to three times. If that doesn't work you will need to replace it. It is a common problem in laptop batteries.
Jul 24, 2010 | Toshiba Satellite P105-S6104 Notebook
Its been stood for 3 months battery not holding charge an is now running lumpy
If you have a gel battery (non acid) which you probably do then you will need to charge this battery properly using a 4ah charger as when this battery gets very low it will not accept the charge rate from your generator or a normal lead acid battery charger you have to charge it with the proper charger untill it reaches a certain point then it will accept the charge from it's normal source.
Hope this helps
Apr 22, 2010 | 2000 Yamaha YZF-R6
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
When I hook up the unit to be charged, it will not accept a charge unless you push the cord in and hold it there. Is there a solution to this problem and if not does the unit have a warranty and will it be...
You didn't mention the model number. Either the cord has an intermittant break or the power connector is intermittant.
If you bought the unit from a well known chain store, the warranty will be honored. If you bought it off of eBay/auction, the manufacturer will not honor the warranty.
Make sure the unit has been registered online with the manufacturer before you call them. You will need to send them both the cord and the GPS as its not clear which has the problem.
By the way, apparently Fixya doesn't like their experts referring people back to the factory (they warned me about this) but if its under warranty, you're best bet is to have the manufacturer repair or replace it for you, free of charge. Sorry Fixya.....there is no better solution to this problem.
- Jim
Sep 22, 2008 | Garmin GPS
My philips mp3 help
same thing happened to me and i charged and it said to connect it to ur computer and it might work
Jul 09, 2007 | Philips HDD1630 MP3 Player
GPS Logo
94 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
