Question about Dell (6F858) Cooling Fan
I have had my dell for about 6yrs, I need to replace both cooling fans and don`t know what to order!
    Problem Solver:
  • 5 Answers
Can't point you towards a specific model of fan or fans without knowing your specific Dell model.. BUT luckily there are standard sizes for cooling fans - quite a few sizes - but since we're talking about a 6 yr old Dell, well that narrows it down a little bit. Here's what you should do first: take a plain old ruler that measures in millimeters/centimeters and take a measurement of one of the sides on each existing fan (don't measure corner-to-corner). Your ruler will be easiest to read in centimeters but most fans are sized in millimeters until they start to hit 120mm and above. Most cooling fans are the same but there are two main jobs they've got to perform: cooling the case, or tower... and cooling the CPU, or processor. Case fans are straightforward and typically measure either 80mm or 120mm, and as I'm sure you're aware, are responsible for exhausting warm air. Let me guess -- is there a dusty green shroud that covers the processor and its cooling fan? Maybe not -- but most of the time these guys were present in 2004-era Dells (as well as today) - and the case fan would sit at the very back and pull air through. (Is the case fan attached using rubber cone fasteners? Yeah if thats the deal then those are toast, unless you're a surgeon for your day job). The rubber plugs are for noise isolation (and cost cutting) but not to worry -- your new case fan will be the strong silent type. Dell probably has a smaller Foxconn or JMC fan sitting on top of a heat sink, which is contacting the CPU (Pentium 4?). That size will probably be 50mm but my recommendation would be to determine what socket type you're using -- and with this information, you can just purchase a new modern CPU cooler (heat sink and integrated fan, maybe copper heat spreaders, yada yada). ---If you're comfortable enough to switch out fans then you can handle a Pentium cooler switcheroo.--- (An instruction manual would be supplied, btw). But you'd just pop the bracket or clips securing the heat sink to the CPU, pull it up and outta there, wipe off the exposed CPU surface with a dry microfiber -- or use wadding polish like Eagle Nevr-Dull and THEN use the microfiber, apply PEA-SIZED drop of thermal paste to surface of processor (paste comes with the cooler), clip on said cooler, and open beer. Here are some links to go look at... (there are literally trillions of online merchants selling compustuff) -- newegg.com is always a good one of course due to great cust svc and practically next-day "ground" shipping; for in-person purchasing, you can't beat Micro Center (microcenter.com), but they may not have a store nearby. Check these guys out - I've used them for Dell-specific parts before and I like how you can search for components based on socket type, processor model, etc... http://www.directron.com/cpu---coolers-cpu-coolers.html This page will list a bunch of socket types from which to choose -- and if you're using a Pentium 4 on a 2004 or 2005 Dimension, for example, you'd probably want to click the Socket 478. If you're unsure, go to support.dell.com and plug in your service tag and pull your orig specs.
(Complete alternative: Dell Outlet Store... refurbished Core2Duo or Core2Quad with 4GB dual-channel memory, or hey I'll build you a 10-year future proof system - you pick the case design - for less $$ and will make Dell's cookie cutter systems look like.. well, cookie cutter systems.) Bestoluck!
Posted on Jul 22, 2010
Cooling fans won't turn on. I replaced coolent
You need a wiring diagram
That would tell you what you did,as
you know what terminals you jumped
Then you look over the rest of the circuit
to continue
Your lucky you didn't short something out
Nov 21, 2012 | Cars & Trucks
Were is the 2004 Jaguar x type electric radiator fans relay at?
I don't know where it is; however, my husband and I have purchased 2 cooling fan assemblies for my 2004 Jaguar x-type 3.0 AWD. Neither of them would turn on. We have since been advised by a Jag mechanic that you must have a part called the link lead in order for the fans to work properly. This is a non-admitted (by Jaguar) default in this car. Check Quality Auto Parts 800-505-5838, ext. 1047 and ask for AMY. Hope this helps Nancy
May 06, 2012 | 2004 Jaguar X-Type
All the blades on the cooling fan have broken off. can a new fan be fitted or should i just kiss goodbye to the laptop? its a dell inspiron 1525. cheers
If money is tight I would try to replace the fan, I seen them on ebay for 10 bucks, but what I am concern with is what broke off all the blades, and did the laptop over heat when it was powered on with a faulty fan. Personally what I would do is order the fan, if it fixes it you did good, if it doesn't fix it then you are only out 10 + freight, and then it is time for a new laptop.
Nov 05, 2010 | Dell (6F858) Cooling Fan
Dell D800 laptop cooling fan issue
If you want to know all the details of your hardware software ect...
I would recommend downloading SIW http://www.gtopala.com/
If the computer does boot up I would simply suggest buying a replacement fan they generally only cost about $10-15 and take only a minute or two to replace
Here is a link to Dell's part ordering page just select your machine type, if its custom made, you can remove the fan and find the part # on it and search Dell's site by the part # http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&s=dhs
If you need further assistance feel free to leave a comment
Nov 21, 2009 | Dell (6F858) Cooling Fan
Cpu fan failure message when booting
Sad to say but this model dell uses a specific fan made for dell. Unless you want to modify your cpu cooling system you will need to contact dell for a system specific replacement part. Hope this helps.
Jan 10, 2009 | Dell Dimension C521 PC Desktop
Dell (6F858) Cooling Fan Logo
222 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
