Question about Bryant 463AAC008BA Air Conditioner
I have a Bryant 661CJ030-E. While in cooling mode
I have a Bryant 661CJ030-E. Hot air is coming off the fan while set to cool per thermostat. What should I do? Do I need more freon, if so, what should I get?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
Refrigerants are regulated by the EPA. In order to purchase it, you need an EPA License. If you are low on refrigerant, the leak needs to be found and repaired. This requires special tools.
Additionally, with the information given, it could be an electrical problem. Is the outside fan running, is the compressor running? Your best bet is to call a professional.
Posted on Jul 22, 2010
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
I've a Bryant AC/Heat system. Model 661CJ030-A. It run cool okay but the fan kept to running even get to the point that has been set.The system seemed not auto stop. Any ideas,
Hi if the indoor fan continues to run after the unit is done cooling, you either have a fan relay located in the indoor unit that is bad or stuck, or a problem in the thermostat with the fan contacts not opening when its satisfied. Pull the cover from the thermostat to expose the wiring. Find the G/Green wire. This is the fan wire. Take a small screw driver and carefully loosen screw and take this wire off. Give it a couple of minutes to see if it shuts off. If it does shut off, the thermostat is faulty and you will need a new one. If it still runs, you will have to check the indoor unit and find the fan relay. If this system is gas fired for heat, it will have a combination fan/High limit control that is the problem, more then likely stuck. Look at the wiring diagram on the panel and it will show you the fan control. You can try tapping on it to see if you can un- stick it. If not, it will need to be replaced. If its just a fan relay, it will be black about the size of a wooded match box with around 5 wire terminals on it. If you have someone turn the stat on and you should be able to hear it click. Do the checks with the stat and let me no the out come and we can go from there.
Shastalaker7
Jun 03, 2010 | Bryant 463AAC008BA Air Conditioner
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Is the Bryant 661CJ030-A heat pump single- or multi-stage?
Single stage heat pump. But you must have a two stage tstat for backup electric heat. You single stage cool two stage heat. The second stage brings on the electric heat in case the heat pump can not keep up. Wiring goes r y w1 on most heat pump tstats are switchover valve or o terminal. W2 second stage heat or emergency heat. g is fan c is common terminal.Rus
Nov 11, 2009 | Bryant 463AAC008BA Air Conditioner
Have a Bryant AC/Heat pump. Model# 661CJ030-A. Problem: Air conditioner not cooling,fan comes on,there is a click and a hum but compressor doesn't come on to cool. Does thermostat have anything to do with...
Found charge capacitor top ballooned replaced with a universal capacitor found at a local appliance repair shop system works like a champ capacitor is located behind the interior electrical panel after removing the side panel
Aug 19, 2009 | Bryant 463AAC008BA Air Conditioner
AC is set on cool & furnace comes on blowing hat air
My first thought is a bad thermostat or control board or maybe something is wired wrong. If all that seems to be working I would look at the outside unit. if that condenser fan motor is not operating then you wont get any cooling. look for a swollen capacitor. Read more
Jun 06, 2009 | Bryant 463AAC005BA Air Conditioner
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
412 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
