Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv wont turn on
We had a storm the power went out several times each time the tv would come back on the last time i had to leave for work the next day the tv wont turn on tried unplugging still wont come on the light on the front of the tv keeps flashing the one that says timer i think it has to do with whenever this did happen in the past the timer display message on the bottom of the screen would always say to fix the time any help would be very much appreciated thank you Alex.
    New Friend:
Green light of death, capacitors have to be replaced but it probably wont fix it anyways. Once this happens the TV is completely useless.
Posted on Jul 25, 2010
SOURCE:
Does this model have a reset button? Had a storm last night, TV went out. Other TV's work but this one flashes a good picture & sound for a moment and then is black again.
In lieu of a reset button, simply pull the power plug out of the wall for about 5 minutes, then plug it back up and turn it on. I've had to do that with my TiVos several times over the years. If that doesn't work, something may be fried in there.
Mar 10, 2017 | Televison & Video
Tv will not power up
Did you try leaving the TV disconnected overnight?
Apr 01, 2008 | Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv went out last night during a storm. TV was only thing effected. not tv will not turn back on. red led light blinks 14 times when try to turn on
hi, normally that because the power supply unit cannot supply the required voltages for various components on the TV , from back-light inverter to logic board etc...
Regards
Rob
www.gewizrepairs.co.uk
Jul 15, 2015 | Panasonic TC-P50G15 50 in. Plasma HDTV
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
Not working
Did you try to physically unplug the TV? Leave it unplugged for a few minutes then plug it back in.
Apr 03, 2010 | Hitachi 51S500 51" Rear Projection...
My Sony 52" LCD kdlw3000 tv, which is almost 2 years old, went to standby mode after our power had been off for two days due to a storm. TV worked fine before we lost power and it's plugged into a surge...
Just as our modern sets can remember user settings when the AC goes off, they well may record error conditions for an extended length of time too just as our cars do. Flash memory (used in such applications and only type used in digital cameras for example) can keep information for a very long time. Even if not used in your set, there is surely backup provisions that can keep info handy for days and possibly weeks by using components that mimic batteries to retain even standard memory for weeks.
Most PCs have provisions for discharging this kind of circuit which then resets possible stored error conditions and returns stored values to factory conditions.
Feel lucky this time I'd say.
Nov 02, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
Apr 12, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Mitsubishi WS-65809 65" Rear Projection Television Logo
272 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
