Yamaha DVR-S150 DVD Player Logo
Posted on Apr 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
REGION 2 YAMAHA DVR-S150 IS NOT PLAYING REGION 1 NTSC, I am asking you to help me with unlocking code so that I acan play all region DVD`s I found that my home cinama station is locked not to play other regions DVD`s if you know the code to unlockit please help me because i cannot play region 1 which is U.S.A., Canada
A
Anonymous
Thanks a lot for your additional help, i`ve got solution already,thanks alot guys
L Jefferson
Level 3:
  • Master 376 Answers
  • Posted on Aug 07, 2008
L Jefferson
Master
Level 3:
Answers
376
Questions
Helped
114973
Points
1060
1/ Power ON
2/ Press PLAY
3/ 274222222005255
4/ Press Play
5/ Power OFF
2answers
I cant unlock my ps2 console to watch a region 1 dvd and ive tried some unlocks but they wont work
make sure your console has the ability to read region 1 discs in the first place.
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs.
If you forgot the parental control code and you need to unlock that, though, then try this:
1.Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under
custom setup.
2.When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3.The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4.Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
3answers
Not playing NTSC DVDs
I can see if there is an unlock code for your device
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
1helpful
Sansui DVP1210 dvd player- unclock code
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 6 -- China
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Multi region dvd not playing region 1
Two issues: if it isn't playing Region 1 discs, then that particular player was designed for use outiside of the US. It is illegal to change the region code, so I would call Philips and get a replacement. But, if you want, there are YouTube videos that show you how to unlock the code - it can only be used 3 times and then it locks up permanently.
Second issue: if it won't play NTSC DVD's, go into the menu and take it off of PAL - if it is stuck on PAL, then that player was definitely designed for outside the US. Call Philips and get a replacement.
The PET940 is the general model number - afterwards is a country code - if it doesn't say PET940/17 or PET940/37, then it is a non-US player.
-Tha Mp3 Doctor
2answers
1helpful
REGION CODE
Dear friend,
Try this method
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Yamaha DVD S1700 player multi-region unlock code
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  5. Press PLAY
  6. Power off
2answers
DVR doesn't read disc, says region doen't match
check the region of the new one probably it is region 4 made in china.your disc is a region one thats the reason why it cannot play on your new dvr which is a region 3 or 4.go on the web and see hw you can hack the code or burn a copy of that same disc.then try it in your new dvr.good luck
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
