Question about KitchenAid KERC500 Electric Kitchen Range
The front right burner gets warm however will not get red hot like the other burners when turned on
    President:
  • 1,430 Answers
This is usually the burner or the receptacle. There is a video that will walk you thru testing and replacing these parts. They are both inexpensive and easy to replace. http://appliancehelponline.com/elementreceptaclevideo.html It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. All parts come with installation instructions.
Posted on Jul 21, 2010
Both front burners won't turn off.
Replace the switches for burners that are not turning off.
Sep 05, 2017 | Kitchen Ranges
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
My 30 year old Whirlpool electric stove burners are heating inconsistently, especially the right front. If turned on medium for a while, it will turn red hot. It happens even faster when another burner...
Each burner has its own switch. I suspect your switch on that burner is bad or going bad. Conracts probably burring up from the constant arcing associated with closing and opening. Here is how it works:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 02, 2013 | Whirlpool RF365 Electric Kitchen Range
The right front burner will not get hot. It is only warm never hot. The burner doesn't turn bright red even when tuned up on high.
hello, try changing that front element(burner)if its easily removable to another side that is working normal. If the element is still dull not heating or glowing normal then replace the element, but if it does, then there is something wrong with the front right element switch or the receptacle.
Oct 30, 2010 | KitchenAid Kitchen Ranges
Burner dosent get as hot as the others
If you saw a spark from the burner chances are that the burner has shorted out and is in need of replacement.
Apr 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
My front burner not working.
Check to see that your simmer switch is in the off position, I just had the same problem and checked it back to the power connector and only had 120 V ????, I about to take the switch out and then saw the simmer switch that I never noticed. Clicked it to off and now my wife is happy again. Good Luck, hope your solution is just as easy.
Nov 07, 2008 | KitchenAid KERC500 Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
KitchenAid KERC500 Electric Kitchen Range Logo
157 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
