Question about OKI C7400 Led Printer
I have a OKI C7400 printer with the fatal error 140... what can be done to reset (clear this) fault?
  • OKI Master
  • 6,826 Answers
Http://esales.okidata.com/oki_dealer_locator.process?dealertype=service&ref_point=MOC
The above allows you to look for a service center.
I read in the FAQ's that a fatal error does not mean your printer is dead.
But, I found no 140 error code, and what to do there.
I also, read the Troubleshooting section of the manual, and no fatal error 140 was referenced.
Also, some error messages refer to toner low, or fuser missing, or other things.
So, I guess it means that you have to have it serviced by Okidata if you want to keep it.
I understand it's a Windows XP era machine.
Might consider a new laser printer that runs with vista or 7.
Posted on Jul 21, 2010
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Strange loud noise coming out of my OKI C7400
If it is a dry barring in the fan you should have it fixed because it will stop someday and you will need a new printer. Well that is just a way to justify an upgrade.
Jul 24, 2009 | OKI C7400 Led Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Cardstock printing with OKI C7400
That machine is rated at 80lb cover I think. You have to use the bypass and select ultra heavy setting in the driver for cardstock.
Jun 10, 2009 | OKI C7400 Led Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Feb 19, 2009 | OKI C3530N Color MFP Printer
Oki 9800 fatal error 230
No reset need to fix fault then clears...
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
OKI C7400 Led Printer Logo
95 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
