Question about Kenmore 24 in. 16032 Built-in Dishwasher
I have a Kenmore mdl. #16032. I have a blinking clean light. Due to this Light or problem the unit will not operate. Prior to this light the dishwasher was a little noisy. What do I need to do to resolve this problem?
  • Kenmore Master
  • 3,247 Answers
I think this is related to the wash arm getting obstructed by either a pan or some spoon stuck at the bottom. That could be the noise you mention.
I have seen people fix the clean light flashing with a sequence of buttons - see below
push the heated wash,and the heated dry buttons one after the other for about 5 times and all the lights light up and the thing just starts going through different settings then it all quits. Push normal wash and it should work.
Hope this helps.
Posted on Jul 30, 2010
  • Sam Aug 04, 2010
    Just wondering if you had a chance to read my posting on this problem you are having. Happy to help if you provide me the additional information I had asked.
My start/resume light keeps blinking
Count the blinks. If 7 blinks, this usually indicates a problem in the heater circuit. You have to be able to check your heater, heater thermostat and possibly your control board.
sometimes you can shut power off to dishwasher for 10 seconds and this may reset your control and allow your dishwasher to run until the fault reoccurs.
Mar 08, 2015 | Kenmore 24" Built-In Dishwasher with Ultra...
The clean light continues to flash and cannot clear. The unit has been noisier lately.
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Oct 26, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Dishwasher clean light blinks
This is due to a problem with heating of the water. I have put together some instructions on what to do and how to reset the control so you can use the dishwasher. Follow the link below and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 07, 2010 | Kenmore Dishwashers
Green clean light flashing and won't restart
This is due to the water not heating all the time, here is a link to procedures to reset the control and things to look for, if it happens again let me know and we can dig deeper to find the long term solution.
Apr 25, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Green light on clean cycle is blinking seven times - cannot reprogram it
this usually means the chopper blade is broken or the sump screen is plugged. you will need to disassemble the sump to check
Jan 31, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Wife left me, dishes are dirty and the machine flashes. what to do. Any women wanting to help me out?
Well here I am. Do you mean that the clean light is blinking? try pressing heated dry and normal wash until all the lights light up. then press cancel. If the clean light is blinking this usually means that you have a faulty heater. Please let me know what the brand name is
Jun 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Clean light blinks
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there was some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics1.gif mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation. To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen to heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that you will fill the dishwasher with hot water water instead of the cool water that is normally in the lines before the hot water from the hot water tank heats the line. This should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
Jan 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Washing light continues to flash
Replace the control electric(control board).
Dec 06, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
