I have a brand new Toshiba 42" LCD HDTV and I want to keep the picture size at 16:9. When I shut off the TV, it goes back to a smaller picture size and I have to make it larger by using the picture size button. How do I make the picture always stay at 16:9 setting.
  • 19,396 Answers
You need to save settings after you go to picture manu.
It will be easier if you save screen format to autodetect.
Posted on Apr 22, 2008
HI, I have a 42 toshiba regza tv that is 3 years old when watching tv the screen goes blank and the sound is still there i power it off then back on and the picture is fine. Somtimes wont happen for days...
If you are using a hdmi cable take it off and switch to component cables if the problem goes away keep it that way. Sometimes the hdmi hookups have bugs like this.
May 25, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
The picture onmy screen is showing up liek a 27 inch buti have a 42 inch tv
Hello nadine hensl,
there should be a picture size on your toshiba remote. Click on it and go to natural mode or any other mode. Play around with it to see which you like best. Hope this helps, good luck.
- Joe
Aug 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Picture size bigger than tv screen.
Please check tv remote for Zoom/ Aspect Ratio button, press it to change picture size as compare to screen.
Hope this will help.
Thanks.
Aug 04, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
I have an 42LG50 and the picture is now a smaller box on the screen and the manual is now help in enlarging the picture, any ideas?
You possibly have the screen set to the 4:3 ratio. On the remote control use the aspect ratio button to toggle through the different size screen formats eg 16:9 etc. this will enlarge the picture to fill the screen.
Nov 08, 2009 | LG 42LG50 42 in. LCD HDTV
42' hd tv has stretched picture makes people look fat
you have a few settings to size the picture as best as it can be sized.
format, aspect and size . try setting the TV (remote) format to full, fill or just.TV size to 16x9.
If also using a cable/satelitte remote set it to 16x9 size, stretch format/aspect and 1080i output. then just press the # key on cable remotes or format key on Sat remotes to size it best on each channel.
with 16 formats available, today's TVs are doing their best to keep up.
hope this helps
Eric
Aug 29, 2009 | HP PL4260N 42 in. Plasma HDTV
When Playing Halo 3... The Screen Shrinks Down...
kyleolver,
16:9 is the widescreen mode, the other size is 4:3 ratio which is what the game's native size, it is picture boxing by the plazma is showing the size as not to distort the image, to get the full screen picture, but make sure it's not the plazma's setting first - where it selects the size of the image, you may have the streched version on your normal play.
randy320sgi
Dec 21, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Picture size does not work
Unplug the power cord for about an hour or more and provide supply to the tv .
At times the power supply can cause this problem .
If you have any substances generating EM waves in and around tv remove it .
Oct 15, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
