Question about Freezers
Fridge Freezer I have bought an LG GWL227YSQ American fridge freezer which won't go through my kitchen door frame without taking the doors off the appliance, the instructions on how to do this, which came with appliance are not very good at showing how this is done, please can anyone send be better user friendly instructions on how to remove the doors, Thank you Denise
  • 121 Answers
The hinges at the top and bottom have screws. These may be hidden under a plastic cover which can be pried off. The water and wiring, will have disconnects at the bottom of door. Take the top ones off and lift the door up.
Posted on Apr 22, 2008
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
We have bought a new american style fridge/freezer and it was delivered yesterday. We have left it on for 24 hours and the temperature is not going down the fridge wont go below 12 degrees and the freezer...
ambient temp 10/35 degrees C.not in direct sunlight,
did you use a level to make sure that it is level in all planes,just to make sure all the door seals are tight,
(look along the seals to make sure)the unit should be left on for at least 24 hours in its chosen position with the doors shut,then check temp,it could take another 12 hours to settle down once loaded.Also make sure that its not touching the wall cuts down on vibration.
once checked,if still not right call samsung..they are good.
Apr 04, 2010 | Freezers
Horizontal fridge freezer - Freezer over-heating
The door frame has a heater to stop ice forming around frame. This is normal. You don't notice it when freezer is cold. The freezer should start working again.
Nov 01, 2009 | Freezers
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
May 01, 2009 | Maytag Freezers
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Fridge freezer
fully defrost it 48 hrs with the doors open and that can often cure it.
Feb 11, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
143 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
