Question about Hitachi 53UDX10B 53" Rear Projection Television
TV makes chirping sound and power button blinks, T.V. does not turn on
My Hitachi makes a chirping noise and the power button blinks. The TV wont turn on. I've opened the back and saw several green lights flashing like the power button button. When I try to make power button stop flashing, I have to unplug TV. PLease Help.
  • Anonymous Apr 27, 2008
    I have the same problem
  • zrtwo Apr 27, 2008
    TV makes chirping sound and power button blinks, T.V. does not turn on. Colors are bleeding when it does come on.
Me too! help!
Posted on Apr 28, 2008
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
Posted on Jun 25, 2008
  • pye003 Jul 01, 2008
    Ok, first let excuse me for the first solution that I make in the 53UDX10B 53 in. I was thinking was a DLP Television but it was a Projection Television.
    The Projection Televisions has others problems, so maybe it is that a Technician must has to solder (weld or give weld points) in some boards (PCBs) inside the TV, (the Main PCB and/or the Sound PCB) and/or perhaps has to change a capacitor (C 33uf 16v) that maybe it is exploded. Because that happen with those old Projection TVs.
    It is the same with the 53UWX10B.
    For all inquiries please call: 1-800-HITACHI and tell then the problem.
    They maybe give you a better solution.
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Jun 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 53UDX10B power button flashes, chirping noise, LEDs flash
The convergence issue might not affect the TV to the point of not turning ON.
The chirping noise you hear, it means there is a short circuit in the circuitry, possible the HOT or power supply assembly.
Apr 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Samsung HCM 4215W when on, no picture timer blinks & chirp sounds
Sounds like a shorted component in the power supply or the high voltage circuit.
Time to call a professional.
Apr 10, 2009 | Samsung HCM4215W 42" Rear Projection...
Tv will not come on
check the power supply , or check the bulb it may need replacement
Mar 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Green Power light blinks but no picture or sound with a chirping noise
That chirp is your ballast trying to fire the lamp. Sounds to me like you need a new lamp. The model should be TY-LA1000. Keep in mind though that the ballast could also be faulty, but 85% of the time it's a lamp. Pull the cover off the unit and remove the lamp. More often than not, when the lamp goes it'll actually break and be obvious.
Dec 12, 2006 | Panasonic PT50LCX63 50" Rear Projection...
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 53UDX10B 53" Rear Projection Television Logo
462 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
