Question about Toshiba 2060 Copier
Close side door
At startup screen displays "close side door" and "100%".
The side door on the right IS closed, and the small plug at the door edge is also plugged in. Copier will not proceed with this message.
The only button that responds is "print" and then the screen displays "wait auto start 100%" but nothing happens.
Thanks for any help!
    Habit-Forming:
  • 41 Answers
Good solutions for u :
1. Cheak all the connectors in cool mind
2. On the other hand this fault may me come from main board.
3. and the last say is this error can come out from power supply.
4. Cheak your closing again.
Posted on Jul 24, 2010
My Ge refrigerator freezer door won't close
Have you checked for ice on the edge? also check the seal. they can warp and cause problems. Last try, is the door warped, like, did someone close it on something?
Mar 09, 2015 | GE GSH25JFR Side by Side Refrigerator
Close section properly
Its not talking about the bypass tray. Its saying the right side door isn't closed. There is a cover above the fuser that may not be closed. Open the right side door and see if you see any broken parts. If everything is closed correctly and not broken, the message will go away.
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
Bizhub 200 has error code c3452
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Jan 23, 2012 | Minolta bizhub 200 Copier
My bizhubb c250 is displaying
open front door then push the IU correctly then close the door and close the side door from your right side...
Nov 14, 2011 | Konica Minolta bizhub C250 All-In-One...
Drawer error
on the diplay panel at the very bottom of the left hand side do you see a small little symblos (wrench) touch it the panel will go to a different display, then once there open and close the front door. its reset procedure. Next try, Open the front door youshould see a cover with a small screw, or if the cover is off, you will see two buttons, one is trouble reset the other is initialize the one to (try 1st) the left the trouble reset to the right, two draws down worked with minolta never had both draws go, make sure once the draws open check behind them for paper. Open and close front door first off also
Aug 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
The cd door on right side will not close automaticly
see left door closing problem, no solution, manually close it.
Jan 30, 2009 | Sharper Image SA260 CD Shelf System
Canon IR 210S "Close the Lower Right Door" warning
Yes there is a sensor that most likely got knocked out of place. What you can do is to turn the copier off and disconnect the bottom 2 trays from the main body of the copier and turn it back on and just use the top 2 trays. You can change the trays lay out to what ever size you want, but make sure you change the BLUE DIAL to the correct size you want to use. I belive the sensor is toward the front of the copier right by the edge of the door, it may be knocked out of place or the flag on the door is broken off or one of the door pins are broken and the door is not closing correctly.... Good Luck..
Nov 06, 2008 | Canon imageRUNNER 210S Copier
Turbochef oven
take the top cover off and then the left and the right side.
look on the left you will see the door position switches. these most likely need replacing. easy job to do
Feb 21, 2008 | Ovens
Display reads "open"
Hi! on my Rio the contacts that tell it if its open or close are at the hinge side, 2 metal ribbons that come down from the cover side and touch other metal parts below them on the base side. I'm not sure if this is the same on your model but check it, if not, then on yours it might detect open/close on the latch mechanism, so check to see if the latch action is normal, or if it feels ****, sticky etc. either way - locate the open/close sensors, and make sure they look allright, not bent, broken or dirty, and see what you can do about it. have a nice day!
Oct 07, 2005 | Rio Volt SP50 Personal CD Player
168 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
