Question about NetGear PROSAFE FS728TP 24Port Ethernet Switch (FS728TP100NASBND)
I press the reset button and the switch does not default what am I doing wrong?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 25 Answers
The reset button only reboots the router. If so equipped, a separate "Factory Defaults" button will revert to (you guessed it) factory defaults.
Posted on Oct 19, 2014
  • 205 Answers
SOURCE: NET GEAR PROSAFE GS108 8 PORT GIGABIT SWITCH
It was on the netgear site. Here's the link:
ftp://downloads.netgear.com/files/gs108_install_guide.pdf
Posted on Nov 19, 2007
ted1430
  • 339 Answers
SOURCE: GSM712 Netgear Switch password reset or recovery
As far as I know, you'll need Netgear's help to recover the passwords and they'll only help if you have a Premium support contract.
Try "1234" as this is the default if password protection is enabled.
Posted on Oct 04, 2009
  • 74 Answers
SOURCE: Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
Posted on May 11, 2010
  • 4 Answers
SOURCE: how to recover from a
The below link will help.
http://kb.netgear.com/app/answers/detail/a_id/10105/kw/Firmware%20Recovery%20Procedure%20FS728TP/session/L3NpZC9ZdUFWZGN0aw%3D%3D
Posted on May 05, 2011
  • 10406 Answers
SOURCE: hi I would like o
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
Posted on Jun 06, 2011
Can i connect a netgear JFS524 directly to acable modem
Yes for sure you can do that.As the connector is RJ45.The only think is that for Thomson you need a cross-wired cable to connect to the netgear JFS524. If netgear do have Uplink port then you can use normal or straight through cable.For more infor Cross-wired cable are use to connect between network devices.
Feb 25, 2015 | NetGear ProSafe JFS524 24Port Ethernet...
Connecting your switch directly to the modem instead of to a router is not a recommended practice. A router has Network Address Translation (NAT) and Stateful Packet Inspection (SPI) which are important built-in security features ( i.e. a firewall). The router also gives priority to certain types of data so that VOIP phone calls ((internet phone service) and streaming media (Netflix, YouTube, etc.) are not interrupted or degraded. As far as I know your switch lacks these features which may then cause problems for some users when the network is busy.
Can you run a cico 2901 router with netgear fs728tp switches in a hybrid network environment?
Way make it so hard for yourself? The media converter may be trying to assign a DHCP address in addition to the router.
Hope this helps!
Sep 02, 2014 | NetGear FS728TP-100NAS 24-Port Ethernet...
How to restore defaults on GSM7224P?
Leave it to me to find the answer right after I post the question. As it turns out, you have press the 'Q' key at a certain point in the console boot output, to get to the boot menu. On earlier models, there was a clear "press 1 to boot, 2 for the boot menu" prompt. On these later models, you have to "just know" when to press which key. And if you don't, you may have the pleasure of searching online for a few hours until you stumble upon the right combination of keywords. :-/
In any case, here is the link, hopefully saving the rest of the Internet thousands of man-hours of fruitless searching:
How do clear the password on managed GSM switch with firmware 10
Jul 31, 2014 | NetGear Prosafe GSM7224P Ethernet Switch -...
Unable to detect my Netgear Gigabit smart switch GS748T via Smartwizard discovery. Earlier have tried reset the switch to factory default but to no avail. Pls help.
First, make sure your switch and PC are in the same broadcast domain/subnet, and that there is a DHCP server in operation.
Second, make sure you are following the "factory reset" procedure correctly (http://support.netgear.com/product/GS748Tv1).
Third, check your version of Smartwizard Discovery, and download a newer version if one is available. I think the latest version is 2.05.05 (download from http://support.netgear.com/product/GS724Tv2).
Sep 28, 2011 | NetGear ProSafe GS748T 48-Port Gigabit...
Have secondhand gsm7312 and don't know username or password. How can I factory reset this unit? There is no reset button and I can't enter menus via console cable as it asks for username (not the...
Netgear FSM (and GSM) switches have an RS232 serial console port. Connect to that using Hyperterm, PuTTY, Xterm etc. at 9600-8-N-1, and power up the switch. Early in the boot process, it will give you a choice of normal operation, or the boot menu. Select the boot menu before the time runs out (usually a couple seconds), and one of the options will be to reset the switch configuration, including the password.
Jul 26, 2011 | NetGear ProSafe GSM7312 Ethernet Switch...
How to recover from a firmware upgrade failure. netgear fs728tp
May 05, 2011 | NetGear FS728TP-100NAS 24-Port Ethernet...
I have several Netgear GS724T switches, the smart wizard seems to discover some of the switch, and not others. However, my biggest issue is not being able to access the web interface. It seem I can not...
This is odd. Note that "on the same subnet" means the switches need to be within the same physical broadcast domain as your computer.
If a port on one of these switches is configured so that the default VLAN is other than 1, it might prevent the switch from receiving DHCP; I'm not sure if it would prevent Smartwizard from seeing it.
If all else fails, reset the switches' configurations with the "Factory Defaults" button to start over from a known state.
Feb 24, 2011 | NetGear GS724T ProSafe 24Port Gigabit...
How do I find out what the user ID and password is to our router we purchased? The person who installed it is no longer here and did not write it down. I need to have cable installed but they need that...
Click on start->run and type cmd
and write ipconfig /all
note the default gateway
open your internet browser and type that gateway
and enter your username as admin and password also admin
and then under security tab ,change the password
or press reset button on your router for 30 seconds.all the password will be gone
Jul 21, 2010 | NetGear ProSafe FS116 16Port Ethernet...
How do you change the default ip on a netgear jfs524 switch
There is a configuration utility program that comes on the disk that should have come with the switch. Install it, only good for Microsoft Systems.Run the utility, it will discover all your netgear switches. Select the switch you wish to alter its IP address. Under system/Switch Information, disable DHCP setting, and enter in the values for IP/mask/gateway that you want.
Feb 17, 2010 | NetGear ProSafe JFS524 24-Port Ethernet...
NetGear PROSAFE FS728TP 24Port Ethernet Switch (FS728TP100NASBND) Logo
405 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
