Question about GE Dishwashers
WATER RUNS BACK INTO THE BASE AFTER CYCLE HAS ENDED
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherWATER RUNS BACK INTO THE BASE AFTER CYCLE HAS - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 22, 2010
Start button pressed , it starts to drain, you can see the water being drained but it does not cycle to wash
I'm presuming that the empty pump just runs constantly? If that's the case, then this is an anti flood protection. Water from a spill has got into the base of the machine and tripped the flood protection sensor. To cure the immediate problem, pull the machine out and tip it on it's side or back about 45 degrees and the water in the base will run out and the flood protection will reset. The real question is though, how did the water get INTO the base? Most common is that someone used household detergent instead of dishwasher powder or tabs and the foam it created worked its way into the base and then turned back to water as it settled. If this is the case, the tip sideways will be a permanent fix. If not, you will need to trace and cure the leak
Sep 23, 2015 | Samsung DW80F600UTS 24" Stainless Steel...
Miele Touchtronic W1213 Front Load Washer: The washer keeps adding and then draining water continuously. One time, the cycle ended and the machine continued to add water and drain endlessly....until I...
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
May 17, 2011 | Miele Touchtronic W1213 Front Load Washer
The dish washer runs but the water does not get hot and therefore does not come to the end of its program
Be sure to run the hot water at the tap for 3 min before running your dishwasher. Water coming into the tub must be at least 125 degrees for the unit to run correctly and wash.
Please take a moment to rate me a 4 if that was helpful. Have a great day!
Dec 10, 2010 | Siemens Dishwashers
I find water in the bin after the cycle has
It sounds like the water inlet valve is letting water enter the machine at times when it shouldn't.
The valve can be replaced and is part number 8181694 it runs about $40.00. The valve can be accessed by taking 3 screws out of the machine top located on the back of the machine, slide the top up and back to remove. The fill hoses connect to the valve in the back and the remainder of the connections are inside from the top.
Apr 22, 2010 | Kenmore Front Load Washer
Motor runs when door is closed but it is not in a
It is draining because it thinks it is flooded. Remove the plinth at the base after turning off the power. Remove two plastic pieces at base and open the base. Mop out any water you find in there and put your hand in to the back left of the machine. There you will find a reset toggle which rises when there is too much water in the base. Reset this and after making sure all water has been removed close up everything and it should work for you. Please remember to turn off at mains before you do this.
Oct 28, 2009 | Frigidaire Dishwashers
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Ice forms at bottom of freezer
Took back off removed drain hose. Took a stiff wire & ran it up the base of the drain and removed some "lint" poured hot water down from inside the unit. It seems to be working properly now.
Thanks
Feb 19, 2009 | Jenn-Air JCD2389G Side by Side...
Water not draining in Gaggenau GI936-760
Can be downloaded from Gaggenau website in pdf form for free.
Sep 12, 2008 | Gaggenau GI936-760 Dishwasher
Dishwasher confused
i suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Aug 07, 2008 | Dishwashers
BOSCH DISHWASHER SGS 6312GB/13 , FD 7810
You have a leak underneath and it is switching the anti flood switch on. Tip the dish washer back at a 45 deg angle, you will probably get water teak out the back, stand it back upright and try it. although it will probably work you will need to look underneath and find where the leak is coming from, my guess is its the wash pump and will cost around 100 pound for an engineer to repair.
Dec 02, 2007 | Dishwashers
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
