Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
I can turn my camera on, but there is no screen or sight for recording or play edit.
    Novelist:
    Sniper:
  • 85 Answers
Normally, if you can turn the camera on everything should work including the lcd. if its just an issue with the imaging sensor, you wont see anything on the viewfinder (for the viewfinder to work you need to close the lcd screen) but should at least see the indicators, same in the lcd screen and view your videos in playback mode. if its an lcd screen issue, there would be nothing coming up in any mode the camera is set to. you can try to reset cam back to default settings (press reset while cam is on, its located on the side where you have the handstrap, just below the speaker), or do power reset (remove the batt and ac adapter for at least a minute). if still the same, your unit may require service. thanks. hope this helps.
Posted on Jul 21, 2010
The vids on my Sony DSC-T90 won't play and I can't record. The camera says' "file error"
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Not able to record or play :
This error may occur in any of the following circumstances:
-The Memory Stick® media is not inserted properly.
-The Memory Stick media is not supported for use with the camera.
-The Memory Stick media may be faulty.
Mar 13, 2011 | Cameras
Camera suddenly will not record
This looks like a relay or micro switch has gone, camera needs looking at.
Jun 20, 2010 | Panasonic NV-DS65 Mini DV Digital...
Time/Date stamp doesn't show up...
this camcorder has a built in rechargeable battery for the memory of the date and time, if you do not use it for more than three months, it will discharge all the way; to recharge, you need to plug camera with ac power for 24 hours and the camera turned off. this should charge the internal battery complete.
Oct 08, 2009 | Sony Handycam DCR-TRV250E Digital...
My video camera won't record or play videos.
I have about 2 to 3 tapes that wont play on any of my cameras. I have lots of footage on each of them.
Dec 13, 2008 | Video Cameras
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Can't playback
my sony camcorder says that is recording. but when i go to play/edit it only shows a blue screen.
Aug 30, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Sony Handycam DCR-HC32NTSC Play Back
Normally the touch screen should be activated, try removing battery to reset settings, if touch screen still does not work, then it is faulty.
Jul 28, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sound doesn't transfer from camera into computer
It most likely IS the .mov file. I recommend buying quicktime pro, $20,  which will allow you to convert the file, or if you get the free version of quicktime, and the video and audio play fine with it, You can use a screen recorder and turn off the "record external Mic" mode, and turn ON "Record Computer Audio" Once you're done converting (or recording) You can go ahead and edit, Hoped this helped- sincerely: animation508 (youtub username)
Jun 18, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
484 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
