Question about Whirlpool LER4634J Electric Dryer
AFTER DISCONECTING THE GAS FOR TILE WORK IT NEVER WOULD REHEAT
GAS IS RE-CONNECTED BUT NOW WONT HEAT
    Guru:
  • 366 Answers
So long as its heating a little, try removing the venting, and see if there an improvement. a clogged vent will greatly reduce if not stop all heat . dont forget to check where venting exits the home outside also becomes clogged.
Now restart it - it should work.
Posted on Jul 22, 2010
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
When I turn on My Whirlpool Accubake Gas Oven, it will ignite and heat up to the tempurature set, but it wont sustain the heat properly and cool down. If I restart it, it will reheat, but still not...
Yes, you can fix this yourself very easily. You need a new temp. sensor. Here is the part to order. There is also a video on that same parts page to show you how to make the repair.
Keep me posted!
Dec 10, 2013 | Whirlpool Accubake RF362LXTT Electric...
Install continuous flow hot water system
I dont know if any tankless that have that installed.
Because as soon as it detects water movement it starts heating and if you continuous movement it will heat all the time. If that happens then something is going give and it wont be pretty. With a tank type water heater it just recirculates back to the tank and get reheated as needed.
Jan 10, 2013 | Bradford White everhot outdoor tankless...
Dryer starts to dry comes up to temp then goes out and will not reheat but you can see ignitor come on but gas will not come on then some times you can smell gas out the vent and its cool what gives
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Whirlpool Dryers
LG Microwave wont heat up
replacement is much cheaper than the parts/time involved, so buy a new one....I have a panasonic combi,and use it as a main oven,as well as reheating my tea.....great for two people,cheaper to run than main oven by 10 to 1.
Jun 09, 2010 | 2006 Dodge Caravan
Does not stay hot
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Try these videos http://appliancehelponline.com/gdryertroublevideo.html
http://appliancehelponline.com/gdryertroubleshootge.html
Jun 04, 2010 | KitchenAid KGYS850LT Gas Dryer
Using ceramic briquettes with lp gas grill
Many people enjoy using Lp/gas grills for their ease of use and efficiency. Frustrations caused by flare ups and hot spots encourage the use of a wide variety of briquettes and other products. Ceramic briquettes are most commonly used because they provide an even heating surface and last for several uses.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. "SOOC" is Copyrighted by Flickr user: Robert S. Donovan (Robert S. Donovan) under the Creative Commons Attribution license. jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.co.uk/images/a05/8n/jr/should-use-briquettes-gas-grill-1.1-800X800.jpg'); }); Types
  2. Gas grills most often use ceramic briquettes, lava rocks or, more recently, ceramic tiles in order to distribute heat. Ceramic briquettes come in the traditional shape, lava rocks are similar to those used in landscaping, and tiles only differ from briquettes by shape. Traditional charcoal briquettes can be used, though they maintain several disadvantages. Use
  3. Place briquettes, tiles, or lava rocks in a solid layer on a screen between the heating element and the grill surface, making sure to leave space for air to circulate. Light the grill and check to make sure that all areas of the heating element are covered, filling any empty spaces. Advantages
  4. Ceramic briquettes, tiles and lava rocks all serve the same purpose. The advantage comes from their ability to reduce flare-ups and hot spots. They can also be used several times, minimizing set-up and making cleaning easier. Traditional charcoal briquettes are cheap and easy to find. They also provide the smoky flavor associated with traditional charcoal barbecuing. Disadvantages
  5. Ceramic briquettes, tiles, and lava rocks are not as easy to find as traditional charcoal briquettes and are more expensive. Traditional charcoal briquettes do not repel run-off from food, but rather retain it, causing hot spots and flare ups. Charcoal briquettes also need to be replaced after each use and are harder to clean up. Warnings
  6. Any additional product placed inside a lp/gas grill should not come in contact with the heating element. Doing so can cause increased stress to the grill, as well as clog vital gas ports. Always maintain a clean grill. A buildup of old briquettes can cause inadequate performance.
May 01, 2010 | Ducane 30400040 Stainless Steel Grill
Applied dark brown glass tiles and those that were cut with a wet diamand blade saw are darker in colour to the others. will cut tiles become the same colour as other non cut tiles?
THIS COULD BE CAUSED BY 1 OF TWO THINGS, WHEN YOU USE WATER TO CUT ANY TILE YOU ARE INTRODUCING WATER TO THE INSIDE OF THE TILE WHICH WILL CAUSE THIS DARKENING OF THE TILE, 2ND WHEN YOU WET CUT USE A SLOW LITE PRESSURE LET THE BIT DO THE WORK TO MUCH PRESSURE AND NOT ENOUGH WATER WILL CAUSE OVER HEATING AND DARKEN THE TILE. HOPE THIS HELPS. ALSO
THIS DOESN'T ALWAYS WORK BUT AFTER CUTTING PLACE TILE IN A HEATED AREA TO DRY OUT THE WATER ,THE GLAZING IS WHAT PROTECTS THE INSIDE
Dec 01, 2009 | RTO 1/8"wet Diamond Glass, Tile, Stone,...
My gas dryer heats at the start but dont reheat up
remember if it glows and shuts off w/out turning on heat replace both gas coils,, than kyou
Dec 27, 2008 | Kenmore 73932 Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
