Question about LG 42LD450 42 in TV
How do I set it to 1080p? I have hdmi cable and box.
    New Friend:
  • 112 Answers
To my knowledge 1080p is this sets Native resolution, the bigger question is is the box putting out 1080p??
Posted on Dec 18, 2010
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
New 50" hisense tv .. unable to use hdmi for cable box .. tried different cables and all 3 hdmi outlets on tv ????
There might be a setting on your cable box for audio output. Use the cable remote and look in the audio section of the settings menu and select HDMI output. Mine is under Audio Digital Output in the Audio/Video menu.
Feb 21, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
I PURCHASED A FLAT SCREEN BRAVIA SONY 1080P TV AND CANNOT GET 1080P RESOLUTION. I CANNOT RESOLVE IT THRU COMCAST; DO YOU THINK ITS BECAUSE I DON;T HAVE THE LATEST SW VERSION ON MY TV. SONY IS SENDING ME A...
Yes Im sure that should solve most of your problem. If you just recently purchased the set it should still be in warranty. Please take full advantage of your warranty and dont't let anybody work on your set but a tech that has been certified by Sony to work on their in warranty products.
Aug 18, 2010 | Sony KDL46EX600 TV
My tv only shows 720p and i am not sure how to adjust it to 1080p ={
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
May 06, 2010 | Insignia 42" LCD Flat-Panel HDTV
Onkyo TX-SR606 takes up to 30 minutes to display 1080p
Please don't rate me for this. Onkyo has been having voltage problems with their HDMI boards in several models. Yours is one of them. They first instructed techs to replace some capacitors, then add some capaictors to repair the voltage problems. Now they want us to replace the HDMI boards but I have yet to receive any (on back-order) Sorry for the bad news.
Mar 23, 2010 | Audio Players & Recorders
How do you set our vizio to 1080p it is currently set at 480p
You really don't think you set the TV for this, if the TV supports 1080p and the device was 1080 capabilities then the TV will recognize this. If you using a cable box make sure your using the HDMI port on the cable box. I have seen in the past cable companies just using the component ports.
Jan 03, 2010 | Vizio GV42L 42 in. LCD Television
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
LG 42LD450 42 in TV Logo
85 people viewed this question
Computer Repairing
Computer Repairing
