Question about Brother LS-2125 Mechanical Sewing Machine
Brother M948 sewing machine - Bottom stitch doesn't sew properly, looks just like a loop and is very tiny. Can't find manual. Can you help? Thanks.
    Genius:
  • 1,788 Answers
Go to brother.com and download a manual for free. Also, try a metal #15 bobbin.
Posted on Jul 27, 2010
  • theboylan47 Jan 27, 2011
    Brother.com do not have a manual for the M948. I tried.
  • jap69ire Aug 19, 2011
    I have a brother 948 sewing machine manual if you still need it
Brother industrial sewing machine bottom stitch slack
Please describe further what you are seeing on the seam? Loops on bottom? Loops on top?
Dec 29, 2012 | Sewing Machines
Bobbin thread loops
try adjusting the top tension, one number or letter at a time on a
piece of scrap fabric till the bobbin stitches don't loop any more
here is a free manual just incase you don't have one, just click on
the link
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Nov 12, 2012 | Brother XL-5340 Mechanical Sewing Machine
Thread wont loop, it doesn't sew?
It loops, it's just that your shuttle isn't catching the loop. The loop is formed on the upstroke of the needle on the back or "scarfed" side of the needle. If the shuttle point doesn't catch that loop, no stitch.
First make sure you have a fresh needle. If still no stitch... take it in for service. (clean, lube and time)
Oct 03, 2012 | Brother SE-270D Computerized Sewing...
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
This machine will sew properly & then start giving me a loop stitch on the bottom stitch. The top stitch looks good. Have changed tension with the wheel that shows stitch length, etc. This...
you might check your bobbin case tension---turn the screw to the left to tighten----to the right to loosen
also after every project check the needle to make sure it's in good condition
Sep 27, 2010 | Brother LX3125 Sewing Machine
How do I adjust the bobbin settings on my Brother XL-3022
Well is your machine skipping stitches? "Not looping" does that mean not creating a stitch? To adjust your bottom stitch you usually adjust the top tension regulator. I can try to help you more in detail check out my forums http://www.sewingmachineryrepair.com/forums/index.php
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Stitches are not connecting top to bottom
Try re threading the machine with the presser foot up.
When you thread with the presser foot down, the thread/string cannot properly enter the tension control.
No control = looping stitching that pulls out.
If you do not have a manual, you may be able to download a free one at Brother's website.
Feb 22, 2010 | Brother Sewing Machines
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
212 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
