Question about Technics SH-GE50 Home Equalizer
How to connect to reciever - Technics SH-GE50 Home Equalizer
    Brigadier General:
  • 8,546 Answers
Be advised that the engagement of any device in a Tape Monitor loop will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Mon as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? That logical problem also plays into the decision to defeat digital sources if the Tape Mon is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
Posted on Jul 22, 2010
What connection do I use to connect a sony blue ray disc to on a Yamaha htr 6030 reciever to play music cd's
You said "...on reciever cd out in the audio box..." but it should the reciever IN that you connect to. Also is the BlueRay player capable of playing CD's ? When you press play on the sony remote, do the seconds start counting on the screen ? (ie: is it playing, but no sound is coming out?)
Dec 02, 2014 | Yamaha Audio Players & Recorders
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
How do i connect my reciver to my lcd hdtv so the audio is coming from my speakers not the tv speakers.
kindly get four audio RF connection wires look for the audio output on the front or back of your tv. one of the output connection is white the other is red.look for the same connectors on your reciever the same colour.but they are marked input.plug the output wires from your tv to the input connection of your reciever.if you have separate speakers, connect the speaker wires from the output connectors of your reciever so you can get sound comming from your tv through your reciever,good luck.
Sep 25, 2011 | LG Televison & Video
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Connected denon avr 1800 reciever to new hd tv. i cant find my reciever manual. how do i set the reciever to play the tv sound?
If you connect your tv's audio output to the reciever's audio input in the (TVor video section) using audio cables only---red & black or red & white) then select TV or Video on the front of the reciever depending on which connection on the back that you use it should work fine!!
Nov 06, 2009 | Denon AVR-1800
I have just purchased a home cinema system: SONY 46" LCD, KEF3005 SPKS, SONY STRDA2400ES RCVR, SONY S55O BLURAY. ALSO A VIRGIN HD+ BOX. CAN YOU ADVISE BEST WAY TO CONNECT THIS ALL TOGETHER FOR BEST...
connect all source devices to the Sony LCD tv inputs. and connect the audio output from the tv to the aux input or any one input of the audio reciever. This way you can just leave the av reciever on and control all the input switching with te tv remote. Avoid connecting all the av sources to the reciever and the tv as a monitor from the video out of the av reciever. Just use the av reciever to reproduce the desired audio and do all the input switching with the tv remote. This will simplify the operation an lessen the chance of someone changing the audio settings of the av reciever.
Aug 29, 2009 | Audio Players & Recorders
How do u connect the surrond sound on the blue ray dvd player
you are tring to connect the dvd to the reciever?
if so use the red, green, blue component connections plus optical or coaxial audio from the DVD to the DVD input on the reciever and the red, green, blue component connection from the reciever to the tv
Jun 16, 2009 | Denon AVR-3805 Receiver
Need unlock code for sony str-dg520 5.1
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs only. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock". I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's. When I bought this one I thought it was going to do the same. That's what I got for trying to save a couple bucks on the cheeper model! Although it is still a good reciever.
Dec 25, 2008 | Sony STR-DG520 Receiver
323 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
