Question about Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator
The water is coming out very slow in water dispenser on my Maytag Model #MFI2568AES,
  • 6,784 Answers
HI. Usually this will be the cause of a damaged valve or a mineral build up inside the valve that will not allow the valve to open fully. This type of mechanical failure can not be repair, due to the sealed state of the assembly. With that said; Use my procedure to inspect and confirm the damage at hand.
Inlet inspection procedure:
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink or in the wall behind the unit). Next; Disconnect the supply line and remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Jul 21, 2010
  • Michael Masters
    Michael Masters Jul 21, 2010
    • NOTE_ Check the filter date of installation. If your filter is old or it has reached its operational limit, it will slow the flow to a halt. In many cases; Replacing the filter will correct this issue, as well. Check the filter date and replace it, if needed, before initiating the inlet procedure.
  • Michael Masters
    • NOTE_Check the inlet lines for kinks and bends as well.
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Door water dispenser does not work
If the fresh food section is not too cold and freezing the water in your fresh food section water storage tank I want you to check the dual water control valve. Parts detail can be found on page 7 of your Click Here=> MFI2568AES Parts Manual Item number 15 is the 67006322 Dual Water Control Valve
If you would like a user manual please go here=> Whirlpool Manuals and Guides and enter your model number. I will be here should you have questions, Thanks Sea Breeze
Nov 08, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Replaced water filter when trying to get water it HONKS loudly and no water comes out
You might have air in your system. Hold the dispense lever down for several second about every 10 minutes until you have the air purged.
Jan 15, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag mfi2568aes makes continuous buzzing noise when water dispenser is depressed (sounds like is coming from rear of machine). Water comes out, but at a trickle. Ice is fine
From your description, the only thing I could think that MIGHT cause those types of indications is the dual water value. http://www.partselect.com/PS2069865-Whirlpool-67006322-Dual-Water-Valve.htm?SourceCode=1&ModelNum=MFI2568AES
IF you are sure that the ice maker fills NORMALLY. If it doesn't then I would suspect the filter.
Jun 12, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Front door dispenser
Low water pressure will cause this symptom. Make sure you have a minimum of 35 pounds pressure supplying the refrigerator with water.
Maytag refrigerator water dispenser not working
you may have dislodged a sensor or perhaps you may have blocked your water line somehow... im not sure about this specific model, but just try having a look at what you did and see if there are sensors around there.. and make sure u havent dropped anything in there wich may have clogged the lines... lets hope its not your solenoid that has gone, sounds unlikely though you never know
Nov 11, 2009 | Maytag Freezers
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
perhaps there is ice holding it in because that tab is all that holds it.
Sep 29, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
263 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
