Question about IBM ThinkPad T40 2373 Notebook
Why does my thinkpad blink on and then go black once I turn it on? The model is T40 2373
    Scholar:
  • 100 Answers
Contact the Thinkline Technical Support in Atlanta GA
here is the number
THINKLINE: 1800-4267378
Posted on Jul 25, 2010
    Problem Solver:
  • 5 Answers
To troubleshoot:
1) connect a video cable to an external display and use keys to switch to external.
2) If the display is visible on external but not on laptop shine a flashlight into the display from the front. If you see dim data but it is not back lit: it is the inverter or the ccl (backlight). If that is the case and yopu have a scope check signals and replace the defective part.
If no equipment change the inverter first, it is cheap and easy to replace.
If it is the backlight tradeoff a repacement used screen versus buying a ccl (not to expensive) but changing the ccl not very easy.
If there is no display externally and you do not see any data with a flashlight - then remove memory reboot and check post codes.
good luck
Posted on Jul 22, 2010
  • 75 Answers
Its having problem posting. You might need to have a replacement of the motherboard and power supply. you can contact IBM if system still within warranty
Posted on Jul 21, 2010
Model 32ld452c. Why is there a black screen and no sound?
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 06, 2015 | LG Televison & Video
Blinking screen after TV connection
dumb question... have you tried pressing the fcn keys to change your video output?
May 11, 2012 | IBM Lenovo ThinkPad L512 444434U Notebook...
Ibm t61 turns on but all I get is a blank black screen.
This sounds rather bad. You're not even getting a "thinkpad" screen?
Try unplugging the power and removing the battery for a minute and attempt to power up again.
If it's still not starting, try removing the memory modules (if there are two, remove one and try powering up, then try to remove the other one). Although I seem to remember that newer thinkpads will still show thinkpad logo and attempt to POST even with bad memory (then throw an error), it's always worth a try.
If the above don't make any difference then I'm afraid most probably your motherboard has failed. In theory you could also try swapping the cpu-I've seen a cpu go bad ONCE in my several years of tinkering with laptops.
T61 is a current model-wouldn't it still be under warranty from lenovo? Might be worth checking the serial on their website. Otherwise it's time to search for T61 donor laptops on ebay - ordering a new motherboard from lenovo parts suppliers will most probably be far too expensive.
Good luck, hope you get it working again!
Raf
Nov 09, 2009 | Lenovo ThinkPad T61 Notebook
I need to unlock the Ibm thinkpad
remove the keyboard and remove the bios battery then put it back together that should fix it
Oct 18, 2009 | IBM ThinkPad T23 2647 Notebook
Same exact error here...
just disable the floppy drive through bios
and it's ok
Aug 31, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM thinkpad t42 boot up problem.
The most common reason is memory.
First, try to reseat (remove and reinsert).
If still a problem, test one module at a time.
Hope this helps.
Aug 17, 2009 | IBM ThinkPad T42 Notebook
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
Hi: I change the cmos batery to my laptop A21m(2628)and continue working good; then I turn off about two weks but when I tried to turn on...wont'turn on. Just blink the ligth of the HDD and make no noise,...
try to disconnect the power and remove the battery then try to install it bak if it continue to blink try to press and hold on pwer buttom for than 15 sec then try to turn ur laptop again
Jun 09, 2009 | IBM ThinkPad A21m 2628 Notebook
I need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Dec 01, 2008 | Arris DCT6200 DTV Receiver
IBM ThinkPad T40 2373 Notebook Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
