Question about Coleman Powermate Premium Plus 6250W Portable Generator
Has gas in carb but will not transfer gas to engine
  • 6,826 Answers
If gas is in carburetor but won't transfer to engine, try to spray down the carburetor 'tube', choke plate and jets with a carburetor cleaner spray. The jets are probably clogged, due to lack of use.
Also, you can try putting carburetor cleaner into the gas tank, a little bit.
If this does not immediately work, then a carburetor rebuild is required, where new jets are put in, and passageways are blown out with compressed air and sprayed with carburetor cleaner in a disassembled state.
If you store the unit with old gas for 3 months or so, then Stabil Gas treatment is recommended. If it's longer than 3 months then the carburetor should be drained or the engine run until it is out of gas in the float bowl.
This may seem a little funny, to do all this, but if one does this, then less expense for carburetor rebuilds can be avoided, over time.
Good luck on this repair.
Posted on Jul 21, 2010
Just installed a new carburetor on a Tecumseh Snow King 8 hp engine. Gas is getting to the carburetor but no gas is filling the bowl and engine won't start
Sounds like the carb needle valve is stuck closed. Try loosening the bolts holding the carb to the engine, then tapping the carb lightly with a hammer. If gas then flows to the carb, re-tighten the carb bolts evenly and not too tightly.
Dec 27, 2014 | Tecumseh Garden
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
Will not start, put new gas in it, stabile in gas, new sparkplug, dry gas in gas. Gas left in it over the summer months, so I sprayed some carb cleaner in carb. It just turns over. Drained gas from bulb,...
It is very common for the jets to varnish up (even with StaBil) and carb cleaner can't get into those areas. You can take the carb off and soak it in carb cleaner.
One method that I try before I take it apart is to spray a ONE second blast of starting fluid into the carb throat. Attempt to start the engine. If everything but gas is ok, the engine will start. Do it only one more time, this time with the choke on full and usually this is enough to get the engine running.
Be careful and don't do this more than twice. Starting fluid is very dangerous to use and will ruin your engine if you use more than a one second blast more than two or three times.
Have a fire extinguisher handy if you motor backfires and the carb throws a flame.
Jan 13, 2011 | Garden
I have a sunny, YY50QT-6, it will start but when I give it gas it cuts off, I think it may be the spark plug but I can't locate it
it is carburetor. If it was spark plug you would not be able to get it started at all. If you know engines then you can get a carb rebuild kit, which will include gaskets. They problem you are having is that the gaskets in your carb have failed, letting air in instead of fuel, so your engine is not transferring the negative pressure to draw the full amount of fuel, thus you can start and idle, but any throttle just lets in too much air.
Oct 09, 2010 | RTO 150cc Moped Gas Scooter with and lift...
Jet pulse carb will not feed gas to engine after start
Make sure the gaskets were installed correctly.
Oct 08, 2009 | Garden
85 E350 Ford not switching from Fnt to RR fuel tank
85 ford 350 econoline van with 460 engine and duel tanks, lost prime on both tanks, cannot get gas up to inlet on carb, it happen after having shot work on vaccum lines, i can't hear the pumps in the tanks making a buzzing noise, i hear a click when i switch from front tank to the rear tank , somewhere under the hood, on the driver side front fender, what is the next step.
Jun 26, 2009 | 1985 Ford Econoline
Craftman leaf blower,not starting,fresh gas,new
How long has it been sitting with gas in it ,did you have gas stableizer in it ,if not disassemble carb and reinstall it will start right up...lou
Apr 22, 2009 | Craftsman Blower Attachment
72 510 with carb issues. Getting gas to th4e bowl but not getting it into the barels and into the engine. Engine fires when I put gas down the carb and quits as soon as that gas is gone. Taking the carb...
OK WHAT YOU NEED TO DO FIRST IS CHECK THE FLOAT HEIGHT FROM THERE YOU NEED TO CLEAN THE METERING RODS AS WELL....I HAD THIS PROB WITH MY 510 AND IT DROVE ME NUTS..LOL
Aug 08, 2008 | 2005 Datsun 510
Coleman Powermate Premium Plus 6250W Portable Generator Logo
455 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
